jetsam
You really know how to take all the fun out of this. Think of the style points I’d lose, if I followed your plan.
I WOULD like a ride in the hovercraft...
That's what BKs DO in shoulder season. Put the wood in once a day, turn it down all the way, you're done. There is no "relight". If heat distribution is poor, use a floor fan to blow cold air from the colder area towards the stove.
There is no pause button once the wood's on fire, unless you want to modify the stove.
So in theory 5 lbs of wood at the min rate would last just over 3 hours (3 hours being 4.8lbs of wood). My question is, would you still have coals you could light off of after say 4 or 5 hours?
The warranty covers thermal degradation, not performance attributes. Combustors are expected to diminish over time. If they collapse, then that is covered.
I did run my cat for 18 years. Did it burn less efficient, yes. A whole bunch less, no. Did it still burn clean? Yes. No visible emissions after 20 minutes or so. So why did I replace it, to try out a new prototype.That is what I guessed understanding that you will never get 10 years out of a cat for normal woodstove burners that burn for heat not joy and want to be efficient for environmental reasons. Possibly if you run at 80% throttle, all the time, it will keep eating smoke but for normal operation in the spring and fall it becomes noticeable that you are using more wood and the stove is less efficient (then a new cat) having to increase the air to stay in the active zone. A 2 to 3 season warranty is all that is really offered in that case as other have noted 10 to 12000 hours is all you should expect to get. Has a cat ever stayed in a stove for 10 years (operated at 5000 hours a year) and operated at 81% efficiency in warmer temps keeping the home at the correct temp? Or will you just need to increase the air flow and heat output as the cat degrades on it performance attributes?
What is the average number of hours on a cat where you should think about replacing it for the environment? Do the cat get re-plated (should I return it to the dealer)?
Regards
I know wood stoves run about 40% excess air but does anyone know the stoich AFR? I can't seem to find it.
No ridge vent ??Well I have completed my wood rack and stacked all of my downed split cherry on it. Hopefully this will be ready by late November for some good heat. View attachment 225399 View attachment 225400
Good one! ....I did use synthetic underlayment w/ button staples though.No ridge vent ??
Slacker !! Lol
Do any of you bother with a stovetop thermometer? And if so where would you place it. It's the Princess I am interested in.
A study was commissioned by the CHC, OMNI Test did the study. BeGreen can probably post a link faster than I can. In short, multiple cats of various ages were studied by OMNI and were found to still burn cleaner after 9.5 years than most new stoves.
Certainly they can be abused...just like any stove. So we need the Rule of 4!
1) Burn dry wood 18% or less. Burn hot right after loading to deal with moisture early.
2) Go out and look up. Operate your stove as per the manual. Not all stoves are the same and ol veteran wood burners need to recognize stoves have changed.
3) Maintain your stove and inspect and replace parts as needed.
4) Install the stove to the Owners manual recommendations and acknowledge all installs are unique, so more stack, draft of fresh air may be needed.
I'll look for the study...and post a link.
Did it burn less efficient, yes. A whole bunch less, no."
Same here. The stove is so predictable it’s simply not needed.I have a stove top thermometer sitting directly above the cat for no real reason other than I had it and that is where I stuck it.
I suppose it keeps the active/inactive thermometer honest since I can look at one now and know where the needle should be on the other.
I would not touch the cat until you have to. The cleaning process would normally only be used after 5-6 years...depending on how much you use the stove of course. A person burning 3 cords a year might clean it much later than someone burning 5 cords a year. Remember, any time you pull a cat, you’ll need a new gasket.Thanks for the reply as this is my first Cat.
1) My wood is sugar maple 15 to 24% +/-, air dried 2 years and brought inside thru a wood shoot and dump trailer for the winter. Wood not a problem.
2) Yes we noted it still burns clean (noting with more air) this is the question.
3) I have my stove on marble with felts on the feet along with a 6" cheater pipe to slide it forward. I sweep from the top (this type stove moved before) and clean the stove also. Have not opened the black box. The stove works and has from the beginning. Stove not a problem.
4) I have had good draft with all my stoves this one is exceptional. The clear distances and pipe all meet Canadian code. This is not a problem.
The observation noted was it falls out of the active zone at dial settings it use to not to and requires more air = faster burning times/load.
I note I need to increase my air by about 12% to keep it in the active zone after about 10000 hours. What should I expect that it will keep running clean but I need to increase the air by 24%, over a new cat, after 20000 or should it reduce initially like this and then stay consistent for the next 7.5 years. If you can not get the burn times that you use to in warmer weather (3-4 hrs less a day than before) I would say it is a not a whole bunch but is noticeable. Will this degradation continue (on a equal gradual trend) or will it stabilize if I leave this cat in.
Regards
