ratsrepus
been running on the hole the last week or so. I love that term. 30 hrs or better on a medium size load
This is so true. My neighbor's Princess looks great in person and with the heat radiating out with the fans on, he says now the kitchen is warm, not so with the old (1991) Lopi. Holds a huge amount of wood too.
I'll send you a load of red oak, if you think we could get away with shipping it via "media mail".Man I wish I had access to high btu woods. I need a full load of Doug fir to get 30 hours on the hole.
Red cedar isn’t even wood. It’s kindling!
I assume that when one says running on the hole it means that the thermostat is fully closed and the only air getting to the fire is through a hole in the flaper doo dad
Curious to hear how the OAK improved your stove’s performance?Stove is doing awesome, been running on 24 hrs reloads for the last 2-3 weeks or so..
Burning cherry, so not a super great hardwood, but makes btu's..
House has stayed 72-74 deg..
You're probably the only person in this thread that's actually seen the space I'm heating ??
I think the rest of em think I'm full of CHITT.. Lol
Outside air kit made a big difference for me..
I bought a princess for in the garage too !!
I don't think it actually improved my stove's performance at all...Curious to hear how the OAK improved your stove’s performance?
Pull your CAT probe outa it's place and clean the buildup off of it, see if that makes a difference, let us know..How many hours do you get on a cat? Mine is up to about 8 - 10000 hours. I note that I no long can stay in the active zone at the same throttle; use to be able at 25 30% air now it must be higher (40%). Still see no smoke but running it on higher air obviously burns more wood and therefore is not as efficient when not required as spring comes. Understand there is variables but what, for your set up, did you note?
I feel really silly. Only now , after using my stove since middle of January, I noticed the needle position on my thermometer. When the stove is dead cold, should the needle be down like mine in the picture? I think someone here was able to adjust his in the past, but now I can't find it.[/QUO
I'm right around there also
When the stove is cold, the needle should point at the last mark at the bottom of the inactive zone. Take 2- 5/16” wrenches and loosen both nuts. Turn the dial to the mark and retighten.I feel really silly. Only now , after using my stove since middle of January, I noticed the needle position on my thermometer. When the stove is dead cold, should the needle be down like mine in the picture? I think someone here was able to adjust his in the past, but now I can't find it.
The red line. There really isn’t a green line.
Thanks Jetsam. I don't feel so bad now!My thermometer has always been WAY off then! My cold mark is roughly where gregbisia's is.
And there IS a green line; I drew it myself!
I'll pull the themometer and let it cool off and adjust it tonight.
