If you have a flat ceiling, hot air will stratify to the ceiling, and be drawn by convection out the top of the doorway (or be assisted out by a fan blowing cool air along the floor to the stove room.) If you turn on a ceiling fan in such a room, you will mix the air, making the room hotter down where you are sitting, and killing the convection loop of hot air out of the room. I wouldn't run a ceiling fan unless I absolutely had to, i.e. with a high vaulted ceiling.
Yep, I also think an engineer could explain it.
"Yeah...
that's the ticket!"
Maybe the design was a bit too "simple" in this case? Here is a picture of the type of bypass I'm used to seeing. Cast iron parts, guides that hold the door in the proper position in relation to the opening, and it's adjustable, front and rear at the hinge and u-bolt, for the amount of pressure on the different areas of the gasket. The bypass door ain't goin' anywhere but straight down on top of the gasket, when you cam it. This is my SIL's Fireview. Same on the Keystone, but even my Dutchwest, a 'budget stove,' has a very similar bypass setup. Granted, a steel stove may not have as many cast parts. I just wanted to show the amount of engineering on this particular setup, and the money they spent executing it. The AS also look a bit more sophisticated, but I can't tell a lot from a drawing.
View attachment 191349 View attachment 191350
I've never seen a BK in person, and can't quite tell in the following pics (in the first pic, door is clearly out of position)...maybe you can explain what is supposed to hold the bypass door in position, or is it "just laying there?" Looks a little iffy from here.
View attachment 191351View attachment 191353View attachment 191354
Depends who the "we" is.
I obviously remain unconvinced. That bypass appears to be a bent plate-steel lift, welded on, and a couple welded-on pieces of round stock. YMMV but with everything I've read about here, and comparing them to the alternatives, I don't think I would be shelling out 3K+ for one of their stoves. Maybe half that but even then, my philosophy has always been 'Why spend money on something questionable, when you can spend a little more and get a product that appears to be relatively trouble-free and better-built?' In good conscience, you guys should author a BK sticky thread for the benefit of the newbs, spelling out all the good
and bad...but I don't see
that happening any time soon.
