I guess you never made you're annual pilgrimage down to Whoville this year!
Me, the Grinch? No, the Grinch is the guy that grabbed an extra fifteen hundred bucks that you might've had to spend on Christmas for your kids, instead!
Happy Pooh Year!
Happy Pooh Year!
Happy Pooh Year!
60 here did the same less the cap. Ran the sooteater up the bypass for the first time. Worked just fine. Very happy with the purchase!No problem Woody I saw the cheap shot and took it... lol no hard feelings
The big thing is I took advantage of a day in the 50's and cleaned the stove out, did a sweeping of the chimney and scrubbed the cap.
Didn't have a lot of build up for 2 months of burning so I'm happy, my mind is at ease, next cleaning comes March 1st.
None at allNoticed in my BK princess insert today that a brick or two was cracked in the back, surely from me chucking in wood... any efficiency concerns with cracked bricks?
Shouldn't be, as long as they are staying in place. If not, apply Liquid Bandage.Noticed in my BK princess insert today that a brick or two was cracked in the back, surely from me chucking in wood... any efficiency concerns with cracked bricks?
I'd try to avoid "chucking in wood" though.
It happens with this pumice brick. It doesn't take very much "chucking"Shouldn't be, as long as they are staying in place. If not, apply Liquid Bandage.I'd try to avoid "chucking in wood" though.
Our stove had 9 yr old pumice brick. One at the back now is cracked, but holding together. I know exactly when that crack happened too. It was me slamming in a second split in a hot coal bed.It happens with this pumice brick. It doesn't take very much "chucking"
And you also live in a much more temperate area. So 9 years there is like 4 here right?Our stove had 9 yr old pumice brick. One at the back now is cracked, but holding together. I know exactly when that crack happened too. It was me slamming in a second split in a hot coal bed.
It's not proprietary, but you are very unlikely to find it locally. A crack is nothing to worry with, it's only an issue if it's falling out of place.Is there anything proprietary about the brick that BK uses or would it be something I could find at home cheapo?
Our stove goes through 2-3 cords a year depending on the winter.I'm just saying, we gotta stuff our stoves full around here. To get these long burns BK owners fill it up. Typically don't burn a few pieces at a time, rather a full load to run 24 hours +. The bricks can take a beating during the process.Could be if it's all about volume of wood, though I thought those magic burners used 1/2 the wood I burn so that should zero out the difference.Our stove goes through 2-3 cords a year depending on the winter.
I run full loads almost all of the time too. Have been since the beginning of Nov. this year.I'm just saying, we gotta stuff our stoves full around here. To get these long burns BK owners fill it up. Typically don't burn a few pieces at a time, rather a full load to run 24 hours +. The bricks can take a beating during the process.
I don't let the stove go out to remove ashes. I just move the big coals to one side and shove the ash down the hole. Then repeat with the other side. I don't intentionally leave ash behind when I clean it out, there will be more in no time!We have had our stove for 4 weeks today and as of yet, I have not cracked a brick, but (much to my shame) have have "tossed" in a few splits that rebounded off the bricks in the rear of the stove. I am trying to be more careful, but the damned thing is HOT when there are still a bunch of live coals and chunks of wood left.
With that said, I still have not removed any ash although I think I might need to pretty soon. The wood I am burning does not seem to make much ash although I know pine allegedly does (fir just seems to disappear in the box with barely a trace). I also remember reading that I should leave some ashes in the bottom of the box when I shovel it out?
Any recommendations without going back and reading a thousand posts? How much should I leave in the box? Thinking I will let it burn out next weekend and let the house heat kick on for a bit so I can look everything over.
You could say that again..when my dad loads his insert up, its like he's throwing branches in an old duck and chuck wood chipper.Lot's of people slam the wood in so I'm sure there are many with damaged bricks. Point is, it's avoidable with a little care in loading.
I actually feel like I beat on the top of the stove more than the bricks. Trying to wedge one more in.
