BKVP
Yes, she can tell you when it was built.Ok, does serial #1120 tell you what year it was made?
allright my wife is in charge of the stove for the first time as im away for the next 40hrs. lets see how those 2 reloads go for her. this afternoon I showed her the ropes, was gone for about 10 min came back in and gave her a pop quiz and she passed! Its gonna be 10° tonight, so either she gets it right or she shivers under the comforters lol
For the last few weeks I've been burning Douglas fir that's not all that dry. Most splits test at around 22%.
You should have no issue with 22% wood. I've run plenty in that range thru my stove. 20% plus or minus a bit is fine.
What issues are you having?
I looked on the bypass plate and I did not see this nut and bolt. I have the princess insert. Is this some other place?There is a nut and bolt on the bypass plate. LOOSEN THE 7/16" NUT FIRST AS IT IS A KEEPER NUT. Then rotate the head of the bolt 1/4 turn, rescuer the keeper nut. Remember the metals expand when heated so do a small incremental adjustment.
![[Hearth.com] 2014-2015 Blaze King Performance thread (Everything BK) [Hearth.com] 2014-2015 Blaze King Performance thread (Everything BK)](https://www.hearth.com/talk/data/attachments/146/146136-bbcbbc5da0d7ae46387c6f469e5ba4b5.jpg?hash=gnqcdc9Nwc)
It's there but you won't see it with the stove pipe connected, I saw mine when I had pulled it out.I looked on the bypass plate and I did not see this nut and bolt. I have the princess insert. Is this some other place?
So what is YOUR Blaze King stove doing right now?![]()
Okay thanks. I ain't pulling the pipe so it will have to be okay. I am wishing I had the free stander! And I am contemplating how to remove the fireplace to put a king inYou have to pull the pipe, you can't miss it!
Now to save enough money and convince the wife!Mine is turning a piece of last year's Christmas tree into CO2 and H2O while my wife decorates this year's Christmas tree in shorts and a tee-shirt.
Picked up a pallet of Homefire logs today, direct from the manufacturer. Actually, they're rejects and they come in a big box strapped to a pallet. The cost was $150. In the summer, the same box is $100. The weight pushed by old Nissan pickup down almost onto its axle but we (the box and I) managed to get home.
Now I'm burning those little sons of a gun and I must say I'm impressed. The temperature outside tonight dropped to 16 degrees. That's about as cold as I've ever seen it here in Bellingham. Yet the stove is pounding out heat. It's a big house and I wouldn't say it's toasty. But it's alright. Certainly much better than when we were running full loads of Doug fir in the 22% range. These "logs" are burning low and strong over many hours. I didn't load that many into the box since I'd never run them before and had heard they might expand. Started off with two together with the wood that was already burning. Then I added some broken pieces a few hours later. Finally, before bed, threw in another two logs. Now it's after 5 am and it's still pumping away.
It's going to take time to figure out the optimal load (unless someone whose used these things can give me pointers). I can see how a big load could potentially overdo it. Also, even a full pallet of these little suckers isn't going to last forever. I'd like to string it out as long as I can. Of course it wouldn't be that big a deal to run over there and grab another. Unloading the truck was a pain but not when one compares it to the amount of work that goes into cutting, splitting and stacking an equivalent amount of wood. Really, it was only a pain because it was so cold outside and the threat of moisture meant I had to get the whole thing unloaded before the sun went down.
You should have no problem filling it up, especially if you can pack them tightly. Your stove will be able to control it just fine.
This is 126 pounds of Eco-Bricks in my stove.
