HP = horsepower . The Princess insert has 2.54 cf box, smaller than the free stander, the PH has a higher BTU rating and I can tell you from running it this week it gets my house warmer than the Princess ever did and I haven't run it nearly as hot as it's capable, I think the Princess Free Stander I a little bit better heater than the insert. Both great stoves but I think the PH is better for my situation.The Progress Hybrid has the same size firebox as the Princess, and they're both rated at 81% efficiency.. what higher HP do you mean?
The Ideal Steel is larger.
Doug you have anThis is interesting. My current cat was not in the best shape, so I replaced my it yesterday with a new Steelcat and it changed the burn quite a bit. The temperature fluctuations are pretty much non-existent now. The cat went ape for the first few hours, but after that it smoothed right out. This was on a setting of 1.25 for the entire burn (which still has a lot left to go than the graph shows).
I think it takes less of a damper opening now to get the cat to burn hotter. Basically, the new cat is more responsive to increases in smoke, and it is awesome.
yes....7/8" at room temperature.Okay, I have my princess insert apart and have a question. I have the tstat turned all the way down and the flapper is still open about an inch? Is that what it is supposed to do???
There is a nut and bolt on the bypass plate. LOOSEN THE 7/16" NUT FIRST AS IT IS A KEEPER NUT. Then rotate the head of the bolt 1/4 turn, rescuer the keeper nut. Remember the metals expand when heated so do a small incremental adjustment.Oh and I did the dollar bill test on the bypass door and it is very loose. How do I tighten that?
No. Follow the above procedure.Okay I did the hair dryer test and the flapper closed all the way. It looks like I have to tighten the bypass door by tightening the cables attached to the handle.
I had her apart for about 4 hours today. The wire that is attached to the bypass lever was severed and holding on by one strand. I had to perform surgery and it took forever to put back together with new wire. But I think I got it. I have been contemplating this design and an upgrade for the past 5 hours. I think I have a few ideas and will continue to think about it as I think it can be better. I also noticed that the screw holes that hold in the tstat are adjustable. It was set with the flapper as far open as possible and I adjusted it to be as closed as possible. I will see what that does. It is neat to see how it all works!! I think you should have to tour the factory and see how they work before you buy one
Poindexter and others is Fairbanks, Fox or North Pole, I will be up your way next weekend and the following weeks through December 3rd.
If anyone wants that offer of a free beer, let me know.
Monday Dec first is good for me. Monday the 8th I'll be coming off a 60 hour weekend call shift and may be asleep.
I agree local burning habits is a big part of the problem. I drove by two of them just this afternoon. If not 100% opacity than 99.9+%. Both of them with plenty of wide open space on the lawn to be five years ahead on seasoning firewood, and still plenty of room to play croquet.
I have read that 400 and 500 yard opportunities are becoming commonplace in Idaho and western OR/WA, making the magnum rifle cartridges practically de rigueur. Hoping to take a caribou from about 75 yards with a 45 Colt pistol next season myself.
When you have time, can I hear your opinion(s) about proposed local air quality regs, cat stoves and bio-logs? I don't see that my exhaust plume is any cleaner running biologs compared to 11-15% MC cordwood.
I concur. I ran an experiment this last week with North Idaho Energy Logs in an effort to be smoke free. Seems the clean air bozos think that biologs have much lower particulate emissions. The NIELs smoked significantly more in my BK at the same settings, same ambient temps. Smokier to start, smokier after 12 hours. They did last a long time, an easy 24 hours on 6 of them.
I also ran a similar test in my non-cat stove and while the NIELs were smokier to start, they burned smoke free after warm up. Just fast, didn't last very long.
Back to 2.5 year CSS doug fir in my BK and the stove is either smoke free or intermittently light smoke during the burn. Cordwood burns cleaner than biologs in my experience. Not sure if smoke=the emissions that the clean air bozos are worried about but visible smoke is what I am worried about.
Chris I understand now what your saying the BK wood stove is a Lot like a high preformance muscle car. One has a car however a little tweek here and their makes a termendunce amounts of horsepower. Someone says they did a 1/8 in 6.6 we want to go equal of faster. Well in our case here we're after a alot of heat example one says 20 hrs @ 450 ....Highbeam,
As you all know I use NIELS. My cap in my King shows slight visible emissions during reload for approximately 8-10 minutes. Once the load stabilizes, my King cruises along fine for up to 12 hours with zero visible emisisons. Then I reload again.
Two weeks ago I was honored to speak at the Stove Design Challenge II held at Brookhaven National Labs. I had the opportunity to share with many regulators the various effects draft has on stove performance. Emissions, burn time, heat transference efficiency etc, all varied when only slight changes were made to varying chimne installs and draft manipulation. (brand of pipe, length of pipe, number of elbows, length of horizontal runs, single wall, double wall, barometeric or key dampers etc.)
It's safe to say that even a 1 gr/hr unit can be made to burn differently (dirtier) depending upon dozens or variables. (Variability being the operative word)
Getting everyone to understand all of this has been a challenge. I have said it before (30 times today alone), no two stove installs are alike.
)Spring bruin 2013, 1167 yards. 338 RUM and NightForce 12x42 NXS.
Monday the first is the day! (Evening)
There seems to be a lack of interest for enforcement responsibility in the Borough/State. While dealers are selling only stoves below 2.5 gr/hr., some merchants are still selling exempt stoves around the area.
For those not up to date on your stove change out (and this will get some comments!) the borough will give you up to $3,400 to turn in old pre EPA stoves to be used towards getting a stove that is 2,5 gr/hr or less. Yet there is no restriction on coal emissions from either the power plants or residential burning.
And if you have an EPA approved model that is rated at greater than 2.5, it too can be traded in for financial support.
It seems to me to be a patchwork of efforts with little coordination from all parties involved.
Highbeam,
As you all know I use NIELS. My cap in my King shows slight visible emissions during reload for approximately 8-10 minutes. Once the load stabilizes, my King cruises along fine for up to 12 hours with zero visible emisisons. Then I reload again. I have said it before (30 times today alone), no two stove installs are alike.
Princess is rated at 1.74gr/hr. Dang good, but just above my upper limit.
Correct. Influences in your example, drop air pressure in the rear tires, advance timing 1 degree, raise octane 2 points, keep engine warm between runs etc. I raced. I made all the classic assumptions....and I hated (and still do) to lose!
Solid fuel heaters are just as complex.
I had a guy the other day say his brand new Ashford 30 was pouring smoke into the dining area of his restaurant. 8' of double wall and 6' of chimney. No elbows. Smoked with first fire, both door open and door closed. Fire died minute door was closed. If he had posted here, classic observations would be:
1) wet wood
2) failure to open by pass
3) insuffient air or blocked passage air way
4) blockage in pipe or cap
5) backwards wound spring in thermostat (ugh)
6) paint curing
7) many more.....
So I called the guy, my rep and dealer both at odds over situation....so I called him directly. In just a few minutes of his venting (nice words for being upset) I told him to go to the stove and we can go over the operation.
When I said turn the thermostat knob to warmest setting he said "what thermostat knob?" He thought the black knob was for the fans. I said no, that would be the rheostat knob located in the lower right corner. He said that knob was missing. I asked about the shaft the knob would be on and he said "oh, I remember I did not order the fans for this stove."
I'll tell you more Owners Manuals are used to start the first fire than all fire starters combined!
