I couldn't get less than 8 hours in my princess if I tried, and I did try when it was frigid I'd try to get as much heat as I could by turning up the tstat as it burned down.
It would over fire, I know some say that's impossible but I didn't want the cat gauge past the 1800 Mark. I guess it would have been ok but I didn't want to take the chance. I have a really strong draft and I think I could have got longer burn times in shoulder season with a damper but it was an insert so it would have taken some imagination.Thanks for that information, but I do have a question. Why would you not have had the thermostat higher for the duration of the burn? I understand that there's still a cycle with a Blaze King, but would it have been too hot or overfiring in some way? I'm really trying to understand this.
When it's cold (<30F), I usually run the stove on medium low with no fans when I go to work, and pack it full. I usually don't know exactly when I am coming home, and I know that the house will cool off a little on a cold day, but the stove will still be burning when I get back. If I am back after 11 or 14 hours, it's all the same. I could run it hotter and maintain the house temp better, but if I was running fans and higher thermostat settings, I'd be looking at low coals or maybe even lighting a fire when I got back.
When I get home I want to heat things up, so I toss a few splits on top of the coals and crank the thermostat and fans, which heats the house up rapidly; then it's time for another long overnight burn. (In shoulder season, it's just one 24 hour load a lot of the time.)
But yes, I think I could get through a full 2.5 CF of wood in 4 hours burning high with high fans. I guess I've never timed it, but that seems within reason. It would have to be exceptionally cold for that to happen, though.
It depends on the outside temperature. Most of the year, the PI is appropriately sized for my application, so I load it once or twice a day, set the thermostat, and don't worry about anything else. (If I had a King with a 5 cf firebox, I would use this exact plan all year regardless of weather.)
In freezing and colder weather, the PI is undersized to be a solo heater for the lengths of time I need it to, so I compromise. I run the stove room up to 75+, pack 'er full, and set the thermostat for a 14+ hour burn. On a sunny calm 32 degree day, I'll expect the stove room to be 70 when I come back; on a day like yesterday when it was exceptionally cold and windy, I'll expect a little less, and run a short hot load to warm things back up.
I only use the fan for catch-up work, never for long burns. (12 hours is about the longest burn you could expect with the fan on low, and shorter is likelier.)
One thing about BKs that doesn't get discussed a lot- it is frigging convenient to be able to do hot partial reloads whenever you feel like it without babysitting and worrying about an overfire. Stick some wood in there and set the thermostat and go do your thing.That one little thing has really helped the PI be my only heater, as opposed to its intended role of occasional backup heater. (
I grew up with open fireplaces and old pre-EPA stoves, and had no idea that 8+ hour burns were possible until I came to hearth.com to find out what stoves were like in this decade...).
I really don't measure temperatures outside of the stove room. I think it usually runs around 5 degrees cooler in the furthest upstairs room (our bedroom; I sometimes close the door to cool it down at night), maybe 15 cooler in the furthest downstairs room.
We really only use a few rooms in the house; I'd probably be using fans to push cold air around (and complaining about downstairs temperatures being hard to raise) if the whole house was occupied.
If I was in your situation, I'd make the switch. I've heated primarily with wood for almost 20 years. The combination of deep firebox and crazy long burn times makes my BK a joy to run. The amount of wood I burn has decreased dramatically too, saving me time, work, and money. I've been away from my house for 48 hours and been able to come back and just throw more wood in the stove without relighting. I wouldn't have believed it if anyone told me that, but it's true. The only downside is that my chimney cap screen gets a lot of creosote on it after a full winter of burning- something that never happened to me with any other stove. Its a trade-off I gladly make. My flue itself is always very clean, just the cap screen gets a black deposit on it.
Sounds like a great deal. My main question would be dealer support. It sounds like may be quite distant. What do you do if something is not right?
Yep- my last stove was the Avalon Olympic. I liked that stove just fine, I liked my Vermont Castings Dutchwest also while I was heating with it. But they were nothing like the BK. Other than not having the light show my Olympic had, and needing to be more careful with how dry my wood is, there is nothing I miss from those stoves.Thanks for jumping in here. I think I have read some old post of yours that made me investigate Blaze King a little more. If I remember you did a comparison to an Avalon Olympic.
If you have the time, I'd love to hear about how you use the blowers if you need to distribute heat and how that works overnight in cold times. Thanks so much.
Heck, for half price,even I might consider a BK...let the chuckling continue.It gave me a chuckle that a Woodstock owner tells me to get a BK, and a BK owner tells me not to.
It also might end up at one of my in-laws', since I'm an 'ash-grate guy.'
I wouldn't expect a huge drop in wood use, but I'd think you'd notice some improvement. From what I've read, the BKs are able to light off the cat quickly, so you should burn less wood at the beginning of the load (as well as less wood at the beginning just because you can run lower.) You can also play with top-down starts (especially with the Lopi) to try to get less wood burning at the beginning of the load.We're wondering if we're just sending too much heat up our flu at the beginning stages of our burn, and if the more even heating of a Blaze King wouldn't be an improvement.
It sounds like he's sometimes trying to get a little more heat out of the coals at the end of the burn, or bridging over to when he wants to do a full load? Not sure...thought maybe the BK thermostat would open and keep the stove temp up in the coaling stage, but maybe it doesn't open enough to do that?Why would you not have had the thermostat higher for the duration of the burn? I understand that there's still a cycle with a Blaze King, but would it have been too hot or overfiring in some way?
I'm not sure about the HRV but from your description of running the Lopi, it doesn't sound like draft is going to be a problem. As was stated, you have nothing to lose by trying the BK; You can bail later if it doesn't work out, and maybe even make money off the deal or at least defray install costs...I should also perhaps mention here that the negative pressure may not be such an issue as we were thinking. Another of our projects for the year, because of some slightly high radon levels at times, is looking into installing an ERV/HRV. I don't know so much about that, but that should be able to help with negative pressure, right?
More even heating is something you sort of forget about after owning the BK for a while. The heat from my stove is very, very even for a good 8-10 hours if it's fully loaded. After that it's a sloooooow taper down for another 8-10 hours. If you look at the first few posts from people with new BK's, you often see the "OMG I can't believe it's still putting out heat X hours later." My first burn was just a few pieces of scrap wood and it seemed to burn forever.
Will you describe your overnight procedure for me, please?
I'm particularly interested in how constant the temperature remains by morning. We load up before bed, run the temperature way up because that's what happens when we load full. By morning we have good coals and the blowers are usually still on, but the room temperature has gone from being in the eighties to the lower seventies or even upper sixties. The upstairs will use some natural gas.
We aren't opposed to using our furnace to balance things out since we are heating two occupied floors, but we were hoping that a Princess Insert would stretch the overnight heating more efficiently so that we wouldn't have such big swings. Anyone have any insight for me on that?
As you can probably see, several of my burning behaviors are shaped by wet wood, and wouldn't apply as much to you- for instance you wouldn't need to be so phobic about letting the fire go out, and you'd have a wider 'safe' low burn range. (The thermostat opens and closes itself a certain amount to hit the desired temp, but if it gets behind on a low burn AND your wood's suboptimal, it may not be able to catch up, cat goes out, burn efficiency suffers greatly.)
I don't have a schedule because I can open the stove anytime to stick a little more wood in; while I do plan ahead to say 'I am going to be gone for 14 hours, let me pack this baby full', I am freed from saying, 'Okay, I started a load 4 hours ago, so I either need to stay up 4 more hours or wake up to load the stove in the middle of the night...'. This is a sweet bonus of the magic thermostat. (It is also counterindicated by the user's manual, which is a sure sign that it is awesome.)
I can't guarantee that 2.5 CF is enough firebox to be the only heat on your schedule, but I can say that a BK has the ability to iron the spikes out of your temperature. Magic thermostat, baby.
