Is there an advantage to loading the stove so much? It doesn't need that many to make a good strong fire. Which way is likely to be most efficient? I'd like to get these things to last as long as possible.
I've got icicles on my chimney too. Was really surprised since there's been no rain recently. Is this moisture from the wood?
For $150 (and $100 in summer) I'd load my garage with those logs. I used to put 3 on the bottom and the rest of the load was wood, used to get real hot and lasted a long time.Picked up a pallet of Homefire logs today, direct from the manufacturer. Actually, they're rejects and they come in a big box strapped to a pallet. The cost was $150. In the summer, the same box is $100. The weight pushed by old Nissan pickup down almost onto its axle but we (the box and I) managed to get home.
Now I'm burning those little sons of a gun and I must say I'm impressed. The temperature outside tonight dropped to 16 degrees. That's about as cold as I've ever seen it here in Bellingham. Yet the stove is pounding out heat. It's a big house and I wouldn't say it's toasty. But it's alright. Certainly much better than when we were running full loads of Doug fir in the 22% range. These "logs" are burning low and strong over many hours. I didn't load that many into the box since I'd never run them before and had heard they might expand. Started off with two together with the wood that was already burning. Then I added some broken pieces a few hours later. Finally, before bed, threw in another two logs. Now it's after 5 am and it's still pumping away.
It's going to take time to figure out the optimal load (unless someone whose used these things can give me pointers). I can see how a big load could potentially overdo it. Also, even a full pallet of these little suckers isn't going to last forever. I'd like to string it out as long as I can. Of course it wouldn't be that big a deal to run over there and grab another. Unloading the truck was a pain but not when one compares it to the amount of work that goes into cutting, splitting and stacking an equivalent amount of wood. Really, it was only a pain because it was so cold outside and the threat of moisture meant I had to get the whole thing unloaded before the sun went down.
Iam not sure if its from the wood. It MC'ed good to go the last split I checked.
We had an 'Extreme weather' warning issued two days ago, I think the snow was blasted into the chimney. It was so voracious the snow has been driven into my wood pile.
Around 30" fell over night with 50-70mph gusts. Temps around -28C with a -37C wind chill. Last night it was -32C air temps.
Lovely.
EDIT: I have a steady stream of condensate coming from the chimney. Its so frikin cold here I have ice on one exposed basement wall.
Mine is also forming icicle on the cap. I believe it is normal when the temps are this cold. Really not a back side effect of an efficient stove. It's -13F here tonight but no wind so that is a plus. Stay warm!
20% moisture means burn 5 lb wood and about 1 lb of water. Plus, any combustion process generates CO2 and water. (What you see from the tailpipe of cars in the winter is mostly steam.) Push both together through a flue and you get icicles.
I thought it was odd seeing them on my chimney as well since this is something new for me. Ive seen them often on the blaze king across the street but not on mine that I can recall.Yeah for sure but I've only just seen them form after the storm. The largest looked to be near 2'. That's the one I was after and it's gone.
Why worry about it? It ain't stuff in the pipe. And icicle fires are kinda rare.
Do you think it would be a problem if they fell off and speared your roof or flashing cone? Maybe slid down the roof and mashed a gutter. Or since they are way up on top they will catch wind and blow the whole stack over? I've only had them form when we have had major freezing rain. Never a true creosicle.
Minus 30 C. In November. You seem to have that "Keep Calm and Carry On" thing going on.
Yeah it's cold, imagine if we lived up north or in Alaska
I did not see that in the manual. I'm wondering what else I'm missingThe BK manual says you'll get icicles when it's cold and to burn the stove hot to burn them off. Nothing to worry about.........
