It will probably bother me now until I adjust it. Until then....
I guess I should have left well enough alone. Over torqued the Allen head set screw and broke my knob.
O'l well, guess I'll install the new one to stop at 6 o'clock when it gets here.
Yep, and with slightly damp wood it may have been going out. A little more air got it burning again. He'll have to watch it with the damp wood. He will think he has the air set right, then the wood will dry out some and the load will take off. Thermostat should counter that though to some degree, correct?Yep you heated the wood up more and therefore more gas's were released. I have have seen that happen here.
After awhile though you will run out of gas though..lol.
Hey, now this is interesting. I kicked the thermostat up to 2.5 and the wood began to ignite. So I took it back down to 2, where it had been all day. Now it's 9:20 pm, a full 12 hours after I started the burn, and it's humming away just fine. For some reason, kicking it up and then lowing it back down smoothed out the burn when the cat was beginning (after 10 hours) to crash. Looks like the stove could go several more hours without a reload.
It's not going to be a 24 burn this time. But we're still way over 12 hours, even with damp fir.
Can anyone elaborate on the Blazeking Princess's Insert's ability to heat without a working fan during a power outage? I have a backup generator, but still curious to know what percentage of its ability to heat will be compromised during an outage. thx
The t stat might have been set just a little to high and too much heat might have went up the flue. Try just a little lower setting.
What type of wood? Seasoned how long? I've been getting very short burn times as well with a brand new stove insert.Hey Folks,
I'm new here and new to wood burning in general. It's my first winter in my house which I bought in May, here in Hunterdon County, NJ. I was lucky enough to buy a house with 2 stoves. The house is a bi-level and the stove downstairs is a BK Princess insert. The one upstairs is a less sophisticated The Earth Stove. Prior owner told me the BK is used primarily and then the Earth Stove for when its REALLY cold. Told me the oil furnace hasnt been used in years.
I am working from home today, so had some time to get the BK going from a cold start. I woke up to my living room being a chilly 57 degrees at 7:30 AM. I got a few small splits fired up and loaded the stove shortly after 7:30. I didnt get it 100% full, but it was a fairly large load of wood. A few minutes of good fire and i flipped the bypass and set the thermostat to the half way mark. Put the fans on low and went to work.
As of 2:30, the cat is just about out of the active zone according to the thermometer. The upstairs living room is 61 degrees, a 4 degree improvement. There's very little left in the stove:
I guess i was hoping for a longer burn time, as I leave the house 6AM and dont return till 7PM on weekdays. This was only about 7 hours. Is this typical for the insert?
good to hear that there is some level of heating capacity without fans for the princess insert, thanks!I have been running mine without the fans so far this year. With the fans on this time of year it roasts you out of the house. (30s at night 50s day) also helps extend burn times a little. Doing half loads twice a day. Saving the fans for the single digit days.
when turning the thermostat down, is it okay that i hear the "click" or does that mean i've gone too far?
![[Hearth.com] 2014-2015 Blaze King Performance thread (Everything BK) [Hearth.com] 2014-2015 Blaze King Performance thread (Everything BK)](https://www.hearth.com/talk/data/attachments/143/143778-f491b4ef596519baae4e9d167e970418.jpg?hash=Mnx7bvMYko)
Remember the problem I was having with Doug fir from my woodshed, cut this past winter. It was working alright. But yesterday I got a call from someone who was giving away some old wood they're not using. So I went to their place and worked hard to get some very large logs down a huge hill. This is about half of it.
The wood is dry inside (like 17%, pretty consistently). But at the surface it's wet. Quite wet. We've had a lot of rain the last few weeks and some of the pieces have a bit of rot at the edges, allowing water to penetrate. So burning still requires an effort to dry it out near the beginning of each cycle. But once it gets going, it goes good.
