Parallax
Well, I'm going to try loading what I got and will report back on what happens. Will let it burn full open until I have to leave for work and then throttle down. Wish me luck.
I've run out of my 15% wood. The stuff in my woodshed, with a fresh split, shows a moisture content of 24.5%. Is that too green to burn in the Ashford? If not, should I run it hotter to prevent creosote buildup? Or do I need to go out and buy duralogs or something of that nature?
An hour later, I'm writing to say "so far so good." The wood took longer to catch. But once it caught, it began burning nicely. I ran it with the cat disengaged for a bit longer. Now I've got it on high with the cat inline. Getting just a bit of smoke, less probably than with the wood I had been using. And that smoke seems less bluish, so possibly more moisture. I've not yet determined how things will run once I throttle back or how much heat it will put out like this. Will update.
Wide Open Throttle, might be other meanings too.WTF is WOT ?
As far as thermostat setting, I'm not sure how closely it can be compared among different units - I know that the knob was actually loose on the thermostat shaft when I received mine; perhaps there is a standard for setting the knob position (e.g. "on a cold stove, the flapper should just close at setting '1'") but I have not seen it - if they have a procedure in the BK factory, it'd be interesting to know.
Dutchwest is NOT an "off brand" product. But it IS an inferior (to BK) one.
My thermo shuts at what would be near zero (if it had a zero) on a cold stove.
Knob stops at 3 o'clock
Yes, this would explain why I'm running at a lower setting than many.
I have read that it's not good to cool the cat fast or open the door until the end of a burn cycle.
I think that's sound advice. Even though you've opened the bypass, it doesn't prevent fire box air from going through the cat, unless there was another door that closed the cat opening as the bypass door opened. If I need to open the door while the cat is still active, I open the bypass and then wait a couple minutes for the cat to cool before opening the door. Also, most of what I've read has said to burn in the load before closing the bypass to prevent relatively cool, moist exhaust from hitting the cat. I wonder if the guys that are opening the bypass, opening the door and throwing wood in, closing the door, and closing the bypass all within a minute are the same guys seeing the cracks in their cats? I haven't seen cracks in any of the ceramic cats I've run lately. Right now I've got a steelie in the Dutchwest. I can close the bypass with about 300 on the probe and it will light within 30 sec. I usually wait until 350 or so to get an almost instant light-off; I figure the less smoke I have going through the cat unburned, the less deposits in the cat. Sure, they will burn off when the cat lights but I think the ash may stick, and I'm guessing it won't just blow right out like fly ash from the fire box will. I want keep the cat functioning at the highest level I can before I have to eventually simmer it out in the vinegar/water solution when performance starts dropping off.Iam Suprised at the amount of cracked CAT's.
FWIW, the EPA tests are run with 20% wet-basis wood (as rdust alluded to,) which equates to 25% on the meter. Like webby says, cook a fresh load off a bit longer before closing the bypass. You can't cook all the moisture out, but you'll get rid of some...My Ashford and my King both handled sub-par wood better than the non-cats I've had. I just leave the bypass open a little longer than normal.
"Everything BK," including the fanboy.You must be forgetting one of the items that sets the BK apart from your off-brand products. The thermostat.
You're talking about the thermostat they were putting in backwards for a while, right, and almost nobody noticed? Don't get me started...
I didn't go back and find it, but I thought guys were saying it was running up to 650 or more WOT. Don't recall if they bailed out and cut the air at that point,and it would've went higher... No problem for a plate-steel stove but probably a little higher than I would run one if (whenWe set it on high but before anything can melt, the stat is trimming back air. I suspect that part of the safety testing for any stove is full throttle testing to see what happens.
) I owned one, without a better reason.Yep, the cat needs time to eat the smoke, but I think creo smoke may be a different animal. It's already gone through a chemical reaction, cooled and been re-deposited on the walls of the box. It seems to me that when I've had creo burning off in the Keystone, even without the air open real far, the cat still wasn't able to catch it. Sure smelled like creo, not the muted wood-smoke smell you get when the cat's eating regular smoke. I'd have to observe the whole thing more closely to make a better judgement. And different stoves, so YMMV...I will admit that during my last full throttle self-clean run there was a lot of blue smoke making it to the chimney cap. The smoke was ripping through the cat so fast that the cat must not have had time to eat it all.
No doubt about that. If anyone is curious about the Dw, I'll swap for any 20 or 30, although I'd prefer an Ashford. Just PM me.Dutchwest is NOT an "off brand" product. But it IS an inferior (to BK) one. I had a Dutchwest for about 20 years before I got my BK. If you can afford it, Woody, make the same change.
The cast box on the Dw is kinda thin and the panels are prone to warping...parts ain't cheap either. I got mine used about 15 yrs ago....don't know how it was treated previously. It has held up pretty well. The primary air control is cheesy, hard to dial in exactly what you want when running the stove low. That said, with the gasket replacement and seam sealing I did, I can snuff the cat if I want with this shoulder draft, if I don't burn too much of the load in. In colder weather, I would have to at least improve the primary air "flapper" system for better low-end control, but the stove might still be leaking too much air to be able to snuff the cat. That, I think, is where the thermostat is useful to possibly compensate for changing conditions as the load progresses but I saw a post, in the last few pages I think, where the poster said the 'stat didn't seem to be adjusting quite the way he thought it would...
Casting quality on the new Dws may not be as good as what I've got, but as far as I know the Dutchwests are selling for a little north of 1000 bucks. Not sure you can get into a cat stove any cheaper than that. If I guy was to buy one and run it prudently, I think it might serve him well for a long time.
I hope I don't get banned.It is an "off brand" for this thread which is specific about BKs.
There's been a lot of discussion here about stuff that's not specific to BKs and several guys new to cat stove that may benefit. I've asked a couple questions about the BKs but haven't gotten the info I was looking for...We can get it all here, from BK to Buck. I guess that's why webby lives here...Very much an off-brand in my part of the country.
Sure, mine served me pretty well for about 20 years. But, I had to work fairly hard to have enough coals in the AM to be able to just throw some wood in there and relax. With the BK, that's the case the next evening, never mind the next morning.... Dutchwests are selling for a little north of 1000 bucks. Not sure you can get into a cat stove any cheaper than that. If I guy was to buy one and run it prudently, I think it might serve him well for a long time.
That will mess with your head. So the "normal" zone is totally wrong for you. I get the cold stat clank at 1.
Parallax, have your smoke issues been resolved? Do you still suspect draft?
Did you check a few splits with the MM before loading?
This is the first time the little 2460 has been back in for a few years, and with the refurb, I'll have to see if it will hold a long fire in colder weather Just burning a load a day right now but we got several 50/30 days in a row coming now. Could it have been that yours was leaking enough air to really cut into the burn times? From what I've seen, I'm thinking it should be able to go overnight pretty easy on some decent White Ash, Red Oak or Hard Maple, even if it's not dialed way down. Lessee, 12 hrs in a 1.4 useable fire box, times 3 to equal the volume of the King...that's a 36-hr burn...damn near BK-esque.Sure, mine served me pretty well for about 20 years. But, I had to work fairly hard to have enough coals in the AM to be able to just throw some wood in there and relax. With the BK, that's the case the next evening, never mind the next morning.
The BK probe is just a re-badged Condor, so you should be able to eyeball it with a Condor and have a pretty good idea what the actual temp is. The fly in the ointment is that Condor apparently has recently changed the number display on the face of the probe, so who knows which one is correct? Maybe it was an attempt to compensate for extra temp off the stove that the old temp readout didn't account for?If BK supplied a numbered cat meter then yes, we would know how hot it is and could verify that the stove is operating within the cat manufacturer's parameters.
![[Hearth.com] 2014-2015 Blaze King Performance thread (Everything BK) [Hearth.com] 2014-2015 Blaze King Performance thread (Everything BK)](https://www.hearth.com/talk/data/attachments/143/143517-88048c2d41c41a9ac4b5fbc6c78b731f.jpg?hash=g_OCoCwF0c)
I've got a few comments ...
WTF is WOT ?
When talking about moisture content and thermostat setting, you guys need to remember that neither is being measured very precisely (so talking such specific numbers may be misleading). I say this because it's well-known that the relationship, between electrical resistance (which is how most moisture meters make their measurements) and moisture content, varies with wood species (see the table in (broken link removed) meters with species correction are probably very expensive (certainly not the $30 one I have). As far as thermostat setting, I'm not sure how closely it can be compared among different units - I know that the knob was actually loose on the thermostat shaft when I received mine; perhaps there is a standard for setting the knob position (e.g. "on a cold stove, the flapper should just close at setting '1'") but I have not seen it - if they have a procedure in the BK factory, it'd be interesting to know.
Stands to reason. I think you'll be OK.something of a monster, and split it again. 24.5% in several places. The smaller splits might be better.
I think the conversion factors for different species are usually only a percent or two, three max, so the cheap meters should give us something that's close enough.I still think our cheap moisture meter readings are fine for general comparison
The draft is still a concern. The installer/dealer called yesterday. He wanted to come out but no one was home at the time. We're trying to set up a visit when he's in the area so it's not a separate trip. My home is 45 minutes from his location.
It was late when I pulled the wood from the shed so I just took the largest split, which was something of a monster, and split it again. 24.5% in several places. The smaller splits might be better. Will check when I have time.
When I get home tonight, I'll check the stove performance and post what happened. Could be anything from the cat crashed to an empty box with just coals. Before I left the house, the thermostat was down to 2 and there was no visible smoke coming from the chimney. The stove was humming along with the cat probe running just to the right of noon. Seemed like a perfectly wonderful burn.
Stove temp?Ok, it's now 7:13 pm. I started the stove around 9:15 am.
Stove temp?
Hey, now this is interesting. I kicked the thermostat up to 2.5 and the wood began to ignite. So I took it back down to 2, where it had been all day. Now it's 9:20 pm, a full 12 hours after I started the burn, and it's humming away just fine. For some reason, kicking it up and then lowing it back down smoothed out the burn when the cat was beginning (after 10 hours) to crash. Looks like the stove could go several more hours without a reload.
It's not going to be a 24 burn this time. But we're still way over 12 hours, even with damp fir.
