Ok all of you turn off your computers and watch the game tonight. You'll have smoke coming out of your ears if you are not careful!!
I promise I didn't mean to cause confusion!
From my manual and posts here, I was confused!
rdust, x2 on a cat a year if that's what it took.
I got it now. Let's move on, sorry for the confusion.
Typical manufacturer. Cat cracked? Log off and watch football.![]()
Not really anything "typical" about Chris. You know he's the odd man out coming on here as a manufacture to represent his product.(Englander also does a good job) I wish more manufactures would become active.
Exacto-mundo; I have NEVER worried about reloading the stove while the cat is still active. I'm not even sure charring the load is that important; my understanding was the main reason was in case there's something unwholesome near the surface of the wood, that would damage the cat if it wasn't allowed to burn off and go directly up the chimney - most likely moisture (even surface moisture on otherwise dry wood, e.g. recent rain or snow).Open bypass, open door, reload, close door, char load, close bypass and enjoy. You're not going to hurt the cat unless you don't open the bypass before opening the door.
Good point, yeah. But actually I don't think the specific temp is that important - just knowing if you're hot enough to be active, mainly. I think we've pretty much decided here that you don't need to worry too much about the cat getting too hot (in a catalytic stove, at least). I replaced my thermometer mainly because the OEM "Inactive/Active" one had gotten so crufty I could barely see the markings.I'm confused why you think that everyone has gone and replaced the OEM cat meter with a numbered one like you have ...
Agreed - and they were probably right.I propose that they decided that this monitoring is not necessary ...
Hotcoals,You see i don't really consider this "performance" thread to be just the basic info. Maybe that is bad on my part..i dunno.
But yes as long as the probe is around 10-11:00 on a cold start and I know the wood has been charred for 15-20 mins I shut the air right down and let her cruise without worry about cat stalls which mostly happen from the wood not out gassing enough. If I shut the air down at 9:00 I ccan get and have had stalls. Sometimes I'll let it go and then she will fire off latter on it's own but in the mean time there is considerable smoke coming out the chimney and i don't like that.
Hotcoals,
Your specific experience relates to your specific application. Draft, moisture content wood density, dimensions of cord wood and other factors influence specific applications.
Casual viewers and new stove owners will not always remember this point and will read in this thread yours and others experiences and expect the same.
I know I'm preaching the the choir, but you and others know from experience and performance attributes how to properly operate your stove and your expectations.
And then all that changes when the zip code changes. I've said it before but it bears repeating....you and others here have saved me many, many tech calls. For that I am indebted to you all.
Keep up the good work.....I may hire you all!
I have a lot of free time since I don't work a 9-5 anymore..just sayin'. lol
Great to have you around here!
My hat is off to you!
The BKK has saved me huge money when it comes to heating my house..even over the non cat BKK it is a big diff. Went from on avg 15 fc's to 10-11.
Also the house temp is way more even through the burn. To me the lower output over a longer time is the best part of it. Not 90f at one end and 65 at the other end! Cheers!
Now send me a new cat probe cause all the printing is gone..that should not be on a 4 year old stove.![]()
Doesn't everyone wake up hourly to check this thread?Everyone else is in bed and no one will read this....so PM me your address. I have some Italian friends in your area that can do me a solid.
Doesn't everyone wake up hourly to check this thread?![]()
Actually, it's also perpetuated by other stove mfg'ers (e.g. Dutchwest) and by the cat manufacturers. I've been reading (and ignoring) it for years.
I can say that on a number of occasions, I have seen the cat thermometer needle pegged beyond the 2000 degree reading, and that, heading into my 6th burning season (with my BK with stainless-steel cat), the thing is still working just fine. Dunno if a ceramic cat would have tolerated this less well or not. (I replaced the dumbed-down "Inactive/"Active" thermometer with the one with actual temperature readings).
I am also confused about people saying you can't really tell how hot the cat is. Seems like the thermometer works pretty well; yes, I understand it's just a steel spring, but I still imagine it's accurate to within 100 degrees or so. The main problem I have with it - and I'd seek guidance on this - is that the "zero" seems to keep drifting; that is, with a cold stove, the needle is well below the bottom end of the scale. I'll loosen the nuts and adjust it, but after not that many burning cycles, it has drifted again. Wonder if somehow I'm adjusting it incorrectly ...
Webby if it's in a glowing state its a free 200' of heat. Just the way I see it.I really don't get all this "active "inactive" talk. If the thermometer says its active, it's active. It doesn't matter what made the catalyst hot, hot is hot! Heat is what it takes to make the cat active. At the end of a burn the only element that's missing is smoke to burn. If smoke was introduced, it would burn, because the cat is hot. Therefore its active.
Wow, if I understand correctly, you have a King in a less than 1000 sq-ft house. That's an amazing testament to the ability of the BK to do long low burns. Though, given all this talk about the necessity of a wide-open burn occasionally to clean out creosote and the glass, I'm wondering how you're going to handle that; wait 'tll one of those cold "Fargo" nights and open the windows, I reckonMy house is a small 550 sqft up plus 400 sqft in the basement...
This past week I have only loaded it 3 times, and not gone below 70 and not above 74F even with outside temp of 30 to 55F.
Now that I have to out, I have dropped down to a 6in pipe then 45 into a straight 12in pipe into another 45 that goes into the clay lined chimney. Its a short basement but the chimney is in the center of the house.
