In my area is says on the gas pump that up to 10% ethanol by volume. I leave gas it in when i store it. I had it serviced like 1 month ago and they changed the filters and everything. I just wonder if they have checked the fuel line. I have had my dealer work on this saw 3 times for this problem with no luck. I wonder if they would normally check the fuel line?
mayhem said:crocboy25 said:Interesting.... thanks for the information. Is that something I could do or should the dealership handle a task such as that?
I've never had to replace one in a saw personally, but other than maybe some potentially tricky routing I really can't see this as being all that hard to do...get a couple feet of the right diameter silicone (or whatever the line is appropriately made out of) and a new fule filter (goes on the tank end of the hose I beleive), pull it apart and have at it.
Out of curiosity, do you use ethanol gas in your area and when you store your saw, do you run it dry or leave fuel in it?
