Vermont Castings Aspen C3 2022
This could be a fun one to watch. It’s doing the thing where it’s running a little hotter than normal, but I can look in and see that the two lights have rolled towards each other and wedged themselves against the walls. All the claims have burned out from under them, so they are slightly suspended as if they were on a fire grate. It’s steady right now with the damper shut fairly tight,so I’m gonna have a Rye and watch this one a while before I lay down. If I see 800STT I’ll open the door and break the bridge. To set the splits on the ash again. Just curious to see if the damper keeps her inline.
Possibly the most full with three pieces I’ve seen this little guy. Loaded it at 9pm.
[Hearth.com] Vermont Castings Aspen C3 2022
Once it caught in turned the damper to about 60% closed.
[Hearth.com] Vermont Castings Aspen C3 2022 [Hearth.com] Vermont Castings Aspen C3 2022
Ran up to 550 then went down to 515, but is now back on the rise.
House was 66 when I loaded it.
25 now with a low of 22.
Looks like it hit 655 in the flue and 700+STT and hovering. Flue 60% closed the whole time.
The warm fuzzy feeling when Tetris pays off! Both stoves running here. It’s not going to be that cold here but the house was 64 when I lit the first stove this morning.
Reactions: 30WCF
