ArsenalDon
Congrats...you have officially scared me into behavingWell it seems like there are a few folks every year that find this out the hard way. The main reason the warning is cast into the ash housing door and on the glass when you buy the stove is to protect you and the stove. At start up there is nothing.....and I mean nothing worse for cast iron then a huge temp difference. The kind of huge temp difference you can experience with the ash pan open. Cast if a fluid material that will expand and contract as it heats and cools. If one spot is 500 degrees and another spot on the same piece of iron is 100 degrees something has to give. Start up is hands down the worst time to open the ash pan door. The stove is at room temp and then in a flash the right side normally is at 300-500 degrees and the base plate will eventually crack. When it does happen if you have two choices, flip the stove upside down and do the repair or take it all apart and do the rebuild with the new base plate. A customer near Hershey Pa just went thru this and had the dealer do the repair. The total bill was over $1,000.00. The dealer had to pick up the stove at the customers house bring it to the shop to do the rebuild and take the stove back to the home and reinstall it. It is not a cheap repair.
Seems like it would be very easy to get jammed open?
