I burn 99.9% hardwood...a full load is waaaaaaaayyy overkill in all but the coldest temps...you apparently don't run your stove like most people do...because that is just about the only control you have to set the house temp where you want it, vary load size. Yeah you can change the air setting, but you can only go so low on modern stoves so load size means more often times.
Yes, on the Kuuma the computer can be changed to vary burn time, but low only goes so low...it is still gonna give the fire enough air to be at xxxx degrees (and burn clean) so you still need to load for the weather.
@JRHAWK9 got me started checking the weight of a load...and I have to agree, its handy. I found that I often misjudge how much wood I am putting in, weight wise.
And no, the "silly metal curtain" doesn't prevent a full load...but it does help prevent even more smoke in the house, especially when loading on lots of hot coals.
