Corie said:Yeah that's quite a delay. We're all back and more or less operating normally.
Tendencies said:Just got an email from the local rep, says her contact from VC is or was at a trade show, hopefully she'll no more from him later in the week..........
T
Todd said:I just got back from Menards and looked at the Dutchwest insert sister stove Century. The only difference between the two I can see is the door. I can see what your talking about. The firebox is tack welded to the outer shroud at the 4 upper corners. And there is actually about a 1/4 " gap underneath the firebox bottom. Could be a place for leveling bolts under there to help support, but I couldn't get at it good enough to lift it and see. If I were you I would demand my money back and look for a different insert. Good luck.
Hogwildz said:Lame that VC/CFM rep is feeding you BS on a show that was over last week. Even lamer the problem hasn't been remedied ASAP.
A "higher gph" SUMMIT would'nt fall apart like that. Looks like quality on the VC front is sliding back down hill lately.;(
BrotherBart said:I bet Vogelzang would replace the stove no questions asked if it was one of theirs Elk.
Tendencies said:That statement concerning the Consumer safety dept. had me worried, (thanks for the tip!) never thought about how many of this type stoves are out there made by VC, was it a bad day for the welder, new guy, short on gas for the welder, poor welding wire, poor design, or a million different things could of caused this. I went to there site and filled out the sheet, pretty easy and no direct flames at the company, only telling them the possibility exists that they may have a problem on a much larger scale and somebody should look into it before somebody gets hurt or worse...
T
There is a process for handling defects.
I, or another qualified technician, do a site visit and visually inspect the stove.
I called the local rep, they in turn called VC (maybe a VC rep) and their response was “are you starting your fires with gasoline?” I about had a fit! (I’m also on the local VFD)
....and you are correct that some customers cannot be satisfied.We have learned that some consumers cannot be satisfied and we are not in the business of baby sitting
...you mischaracterize what I said. T. has given them TWO chances so far, and they’ve effed up, seriously. But neither I nor anyone else has suggested “going for the jugular.” (That would be hiring a plantiff’s atty and filing suit.)Let’s give them a chance to make it right before we go for the jugular!
The house is not going to burn down because the stove body slipped down a bit.
3 welds completely let go on the left side.
For god’s sake. We don’t live in perfect world.
Why can’t we work these things out without threatening one another with court action?
Hummm let’s see-
- $2500 on a new insert, literally falls apart after 6 months due to 3 failed welds and a bad design.
- Company recommends that the customer fix it themselves since they are a welder.
- BS excuses about techs still being at a trade show that is over.
I think tendencies is pretty calm considering, I would not be. I am not recommending taking legal action, I would let it take it course first, but the foot dragging would sure piss me off.
There are over 2mill VC working stoves in homes. The reason we do not hear a lot about of other stoves, is there sampling is rather meager in comparison. Naturally one hears more VC issues than any other stove manufacturer What we do not hear is the millions of satisfied customers, only the few that experience QC issues
VC is coming out of a very precarious financial situation they are fragial and are banking on their flagship of clean burning. I hope they make it ,susceed....
Well, let's see:Lets see if this can be done expediently.
Part of my appeal to them is I share the patriotism of supporting Americam manufacturing and American Jobs. Imagine if the plant close what that would do the the small towns in VT. It would leave a void in ther economies that would take years to recover from if ther ever did.
However, as I say, VC's response has, to date, been mostly footdragging, with allegations of customer-abuse being VC's opening bid. Insulting the cust. is not the way to go.I fully support bringing in the heavy response if VC draggs its feet.
before you diss the crap out ov VC please tell me one other manufacturer that has personally solved stove issues on this forum?
me why there are millions of satisfied customers ,or do you support what little Amnerican manufacturing we have left.
elkimmeg said:First of all this is a mom and pop dealership. I doubt they have inventory in storage to swap it out. What it really sounds like is poor distributor support.
Originally I thought I could help in this situation, but I have doubts. All my connections are of VC this is a plate steel sttove not manufactued in Vermont, but either Indiana or Canada
Part of the Century line of CFM.
I know not all have the tools or mechanical ablities but This stove would have been fixed with out much to do. One i would be pissed that it broke. then My rational would come around that If it is going to be repaired I might as well do it myself. It has nothing to do with warranty. Its trust in my own abilities. I know I will grind off the faulty welds and do it better that the original. Why should I trust someone else, unless I know they are better than me ,at doing something. The other factor I loose no work waiting around for installers I pick the time of repair and I know its done right Not all feel that way and that the company should reinburse me something, that would be fair.
I have owned a fair amoung of heavey equipment and if I waited around for mobile repair I loose a lot of money even if covered by warranty. I had situation where trucks are involved and multi pieces of equipment waiting around could cost me
more than $800 an hour. My car has free oil changes for life. The dealer is 24 miles away by the time I drive their both directions, I find it easier to do my own oil changes. I pick the time.
It takes me less than 15 minutes but I would loose 3 hours having the dealer do it. When one reads the warranty CFM has the right to repair. Simmilar warranty is common in most appliance manufactures. Honestly 3/4 tack welds is not a big deal or that time consuming. I doubt it would take more than an hour. ITs not like CFM did not offer the most expedient way for it to be repaired and also offered you the choice of hiring the best welder in the area and they pick up the tab
! Then I'd be going over this stove with an engineering team to see if 1) it's missing supports elsewhere, and/or 2) if indeed only a few welds support the innards and then I'd be ordering engineering changes or demand that the stove line be dropped (no pun intended).
!We use essential cookies to make this site work, and optional cookies to enhance your experience.
