In the 13 / 14 BK performance thread before it was locked, it was asked how deep the belly on the 30 series stoves is. It's 3" from the top of the firebrick laid on the stove box floor to the top of the bottom door opening.
Just out of curiosity, I pulled the pan to see how much space ash from a week+ of 24/7 burning occupies:
I had originally thought it needed to be bigger, after using it for a few months I think it's just right! If it was any bigger all your good coals would go down with the ashes.I had a chance today to use the ash pan in the pedestal. With the 1450's lack of an ash pan, I was used to the scoop and dump routine with the mouth of the pail held up to the door opening to keep the ash in the box or up the flue. Having never used an integral ash pan before, I was pretty curious to see whether it was a positive or not when compared to the Sirocco's other fantastic features.
After 9 days' burning, the ash bed wasn't overly deep:
I dug around a bit with the poker / hook tool that came with the stove to hook the plug and pull it out:
My first impression is that this hole seems pretty small. If it were up to me, I think I would increase it to double the size:
It took me all of a minute to push the ash build up to the front of the firebox into the hole with my coal rake upside down:
I kept in mind some of the complaints about the plug not sealing properly, so I made sure to scrape around the top of the sealing surface before putting the plug back in. I also determined that one of the tines on my rake fits into the loop on the plug top. I'll probably hit the end tines with my grinder to thin them out slightly to fit properly:
All in all, I am pretty happy with the ash pan in this stove. I definitely think the chute could be bigger, but even with it's current size, it gets the job done![]()
How long does it take to fill up the firebox with ashes if you don't dump them?
In the harman i can go 2 weeksHow long does it take to fill up the firebox with ashes if you don't dump them?
In the Nc-30 Englander just a few days
It seem the harman ashes burns to a fine powder,not so much with the englander.
3 days burning in not much wood. Likewise when it starts to cover the doghouse. Perhaps i have a weak draft,might make a big difference. Its connected to a 12" flue so when the fire dies down so does the draft.Seasoned Oak...a bit off topic but how much wood are you putting through the 30? I went through a little over a cord of pine before I needed to empty the ashes in mine. I've been burning red oak since and it looks like I'll get close to a half cord before I need to empty them. Maybe I just keep the stove full of ashes? I usually empty when the ashes are about an inch from the top of the doghouse.
I paid about $3400 for king ultra with blowers up in ak 2 years ago. Prices can vary coast to coast.are most blaze kings around the $3,000 mark if you want to heat around 2,000 sq ft?
I decided to try and address the slight smoke smell that seemed to be coming from under the convection deck. I replaced my SBI flue thermometer due to the stem sagging from what I assume was from the high temps in my 1450 pre-key damper, so I re-purposed the magnet and "gasket" that shields the spring from the pipe to try this. The magnet is strong enough to hold the gasket to the stove top, so I pulled the cat probe, slid the gasket/magnet over and replaced the probe through the gasket.......
I'm happy to say the smoke smell is now gone![]()
