It heats up fast once i get there and fire up the wood stove. Basement will go to 70 in less than an hour. I use a barrel stove in the basement and an englander NC30Sounds like some cold floor boards.
That sounds like a lot of effort and expense for just a 3 degree improvement. Looks like the law of diminishing returns applies here. Iv been able to achieve great improvements with just air sealing alone. Im afraid future improvements will be both much more costly and less effective.My basement never gets below 55 degrees. Most years now , sinse I insulated the inside walls it doesn't get below 58. I have 2" styrofoam outside and R11 inside .
So what was the name of the glue?...If you do go with foam interior, beware of codes requiring a fire-proof covering. I simply glued drywall on top of the foam, with the right glue the drywall ripped before the glue, way stronger than screws.TE
I would think the foam would rip before the drywall or the glue.I I simply glued drywall on top of the foam, with the right glue the drywall ripped before the glue, way stronger than screws.
TE
I did the same thing with good results in one area where i needed more space around a toilet for code compliance.I simply glued drywall on top of the foam, with the right glue the drywall ripped before the glue, way stronger than screws.
That's not no heat.It heats up fast once i get there and fire up the wood stove. Basement will go to 70 in less than an hour. I use a barrel stove in the basement.
The no heat part is overnight and weekends. Barrel stove goes out quickly after you stop filling it. Latent heat dissipates within a few hours. At this point there is still zero insulation anywhere in the house and no drywall yet. I have a 220 gallon rain catchment system in the basement which froze last year and ruined the pump. This year so far with air sealingThat's not no heat.
With the "wrong" glue, the foam would give way behind the glue, although even that took far more force than pulling out a drywall screw, but with foamboard glue, it didn't. I tried a few small test pieces as I was gluing and the drywall tore first, and it took a lot of force.I would think the foam would rip before the drywall or the glue.
With that 2 inches of foam on each side plus the batts your sitting on about r30 worth of insulation. Sounds like the op has no insulation so he isn't going to be able to keep it above freezing without heat.Seasoned oak, you have to have an awful lot of air coming in. My 2200 sq ft basement never got below 52 degrees. You are loosing a lot of heat. I have a new home. The floor truss cavities are closed cesll foam.. The outside has 2" foam and the inside is insulated with some 2" foam and fiberglass batts . It is framed and it has 1/4" plywood over it. . The only bit of heat is from the water heater. It might get some from the 1000 ft of staple up pex but before the pex it never got below 50 degrees anyway.You could raise your temps 10 degrees if you insulate.
I have been keeping it at 40 with no insulation except now that i have the floor torn out above. The cold drops right down and overwhelms the 40 degree floor. As soon as i can get the new floor in above ill be back above freezing. should take about 2-3 daysWith that 2 inches of foam on each side plus the batts your sitting on about r30 worth of insulation. Sounds like the op has no insulation so he isn't going to be able to keep it above freezing without heat.
