We need the box for kindling; Is it OK if we just throw the dirt on ya?Put me in the box and throw on the dirt.
That is fair. What would change your confidence? And, the real question is why do you fail to have the confidence to begin with?
I burn, therefore I am.
Might as well bring in Descartes.
Yes other than my dealer. I don't feel like paying the markup.Other than your dealer? I've heard folks claim that Condar sells Durafoil SteelCats, but the Condar SteelCats I bought for my Jotuls were very clearly diesel foil.
has anybody figured out where to buy the good durafoil steel cats?
Two independent forces at work, here. A completely depleted cat can still reburn in non-cat fashion, if you keep it hot enough, it just can't do it at 450 or 500F. So, in your statement above, your observation is not conclusive proof of cat vitality, unless your saying it still stayed lit at low burn rates.Everytime I thought my cat had died I came to realize I was burning less than seasoned wood. I put dry wood in and it acted like it was brand new again. Imagine that...
Not even a cat stove. The non-cat portion of that hybrid is strong.
We don't have the cool alien tech knob but the IS will defiantly go full blackout with a glowing combustorThe cat still glows bright red like any other catalytic stove on a low burn. The low air settings do not yield any visible secondary activity.
Looks good! I notice the site says no gasket required, I imagine there is a lot of play without it that thermal expansion wouldn't make up for? Did you buy it from the condar site directly? I'm in the market for one.View attachment 186440
Durafoil it is
Yeah I bought it directly from condar. I have not tried the fit, but Tarzan has and said it needed a gasket. His post about this is above yours. I bought it as a backup in case something happens to my ceramic one. I bought gasket material from firecatcombustors.com. They sell it by the foot and this is where blaze king buys their ceramic combustors from.Looks good! I notice the site says no gasket required, I imagine there is a lot of play without it that thermal expansion wouldn't make up for? Did you buy it from the condar site directly? I'm in the market for one.
Not a hijacking! Just for clarification.Hope no one gets mad for resurrecting this old thread. It's related to the problems I'm having with my Woodstock FIREVIEW.
The stove is about 6 years old. I bought it new. It came with a "Diesel Foil" catalytic combustor. The combustor relatively well for about 2 days of burning and lost most of it's efficiency. I could not get the stove to get over 400 degrees, even if I tried. When the stove was used according to the manufacturer's instructions (preheated, bypass closed, air set to 1), the stove would hardly get over 300 degrees. Wood was seasoned but obviously not "bone dry".
Woodstock replaced the combustor on warranty but the second combustor lasted about the same and basically failed soon after. Nothing is wrong with the stove. Woodstock reps had me check a few things and everything was fine. They mentioned that they also have a ceramic catalyst and I decided to try it. They sent it to me free of charge as it was on warranty.
The ceramic combustor was MUCH better. The stove was "alive" and easily heated to proper temperature with a much better efficiency. I could run a load of wood all night long, at very low air setting.
The new ceramic combustor lasted about 3 1/2 seasons (Dec - March). Currently it barely works. The bottom of both elements is crumbling. I don't think it will last through the rest of this season.
I would appreciate if other FIREVIEW owners share their experiences with catalytic combustors. Unfortunately Woodstock no longer sells ceramic elements. They only sell the new stainless combustor for $150. Condar sells ceramic unit for $201. For some reason they no longer offer a stainless unit for this particular stove. I'm trying to decide which elements will offer better performance and longetivity.
