Those racks are great!I want to build more of a shed in the future, but these racks have been working fine for the past few years.
Yea! They work for sure. I currently have 5. I want to do the shed to tidy things up a bit. Will probable do a 6x12x8 separated into 2 bays. That should hold 3 cords of wood give or take.Those racks are great!
I got around to modifying my woodshed finally. Instead of dismantling pallets and filling in between the cross braces, I actually replaced the cross braces with pallets running horizontally on the back wall. Used one full and one cut in half long ways and ended up with just a small space along the top. This works really well and definitely speeds up stacking, and the outside of that back wall of pallets will be perfect for attaching lattice to.The advantage of doing that is you can almost throw your splits against the back wall and know they are going to stack. It really speeds up filling the shed versus carefully aligning one split on top of another. The second stack butts up against the first. I find that the gaps between my splits are greater which allows for more airflow then when I was tried to stack on only pallets as I had to make sure the stack was stable. Back wall and sides make a big difference.
Glad to be of help.I got around to modifying my woodshed finally. Instead of dismantling pallets and filling in between the cross braces, I actually replaced the cross braces with pallets running horizontally on the back wall. Used one full and one cut in half long ways and ended up with just a small space along the top. This works really well and definitely speeds up stacking, and the outside of that back wall of pallets will be perfect for attaching lattice to.
Thanks again for the suggestion!
Thanks! My plan is to abandon this location@creitzell I would raise the platform higher and putdown a sheet of plastic under, also be sure the ground slopes away for drainage.
I'm not in Normandy; just over the Sarthe border in the MayenneThat is so French. I love it. Looks like the roof could use some help.
Did you say u r in Normandy?
I see you don’t have traditional footings. I was considering building a shed like that due to my rocky terrain. I was concerned that without any serious weight that a strong wind may catch the roof and blow it over.Just finished it, faces due South, hoping to get all that wood split and in it so I don't have tarps draped everywhere!
No floor, I have a bunch of pallets that I'll be using this year, if I feel it works better with a floor I can build that later.
Will do! Especially if something "interesting" occurs... which would be tragic for me, but entertaining for others...I see you don’t have traditional footings. I was considering building a shed like that due to my rocky terrain. I was concerned that without any serious weight that a strong wind may catch the roof and blow it over.
Keep us posted on how it works without a floor to weigh it down.
Looks great! If either of us think of it I'm really curious how those footings perform over the next few winters. I thought about going the same route but my back yard is fairly wet and gets frost heaves. I am going to need to dig footing holes when I build mine.Just finished it, faces due South, hoping to get all that wood split and in it so I don't have tarps draped everywhere!
One of my bigger wood sheds doesn't have a floor. Its 8dx18wx7h. Built it out of pallet racking. Got the feet sitting on 16x16 cement pavers. I put gravel down and then pallets on that. Pallets showing no signs of rot. Its a 2 year shed so one side is always full and helping hold it down.Just finished it, faces due South, hoping to get all that wood split and in it so I don't have tarps draped everywhere!
What are the dimensions on your shed?Glad to see someone started a new woodshed sticky thread.
Here's my shed I just built a month or two ago. Holds about 5 cords.
