I already got a can of DRYLOC so im going to try it and see what happens. As i said im only trying to direct the water away from the surface of the wall down to the french drain on the perimeter of the basement. Ill post the results.
Yeah, I kinda figured that's what it was, but still, back then a LOT of basements used cinder blocks because by the time you got everything setup for the pouring and got the equipment there to do the pouring, it was a HUGE task. Much easier to deliver the blocks and do it bit by bit.
Make sure you are well ventilated and pay attention to the warnings on that dryloc container. Wear a mask, that stuff is NASTY! I did my basement walls a few years ago. My lungs were burnin!
also with ventilation you must not have any open flame ...water heater....or oil burner....a couple of years ago a father and his son coated the basement walls with that stuff...water heater kicked on.........both dead....true story.
Was just at a friend's house. Finished basement, real nice, recessed lighting, new kitchen appliances. Any who, one corner of the poured concrete wall leaks water when it rains really heavy. Outside that is a pressure point for water as his neighbors backyard and his own backyard slope down to that point. He has a pump in that corner too, but it does not help much.
He just painted that corner with a sealer. He could not remember which one. Looks nice and solid. But it was leaking again in one spot. He says it probably is a crack he did not seal properly.
