Screw broke on inside of door holding glass
troy-pit
75
Everett WA
I broke two screws in my cast iron door that hold the glass in place. It is pacific energy. Seems like I can not remove old screws and need to tap and put new screws or drill and put some self tapping screws. Any advice on type of screw and what route I should go.
Kevin Weis
781
Union Bridge, Md
Drill out using a small enough bit so you don't hit the existing threads. Also mark the depth you want to go on the bit with some masking tape so you don't go too far in. What's left after you drill should come out fairly easily with a small pick If it's rusted in there good drill the width of the screw an re-tap with one size bigger if you have the room. Just my thoughts.
bholler
Chimney sweep
Staff member
Jan 14, 2014
18,617
central pa
Exactly what kevin weis said.
Ashful
14,890
Philadelphia
I keep a full set of left hand bits for this task. Most of the time the fastener spins itself out before I’m even done the drilling. Learned this trick from an old engine mechanic.
Reactions: begreen and edyit
edyit
817
Wilmington NY
Left hand bits are amazing for this type of fix. Use them often when working on hydrants that have seen 30 years of road salt....
Reactions: begreen
troy-pit
75
Everett WA
Thanks for the replies. I can probably do what has been suggested but it seems like the cast iron is difficult to tap. I heard that self tapping screws were used. I was given zinc coated self tapping screws from hardware store and I am concerned they may not hold up to the heat. The previous screws seemed like they were self tapping screws of a durable metal. I contacted pacific energy to get a hold of them and they have not responded. I am really not happy with their customer service or lack of.
begreen
Mooderator
Staff member
Nov 18, 2005
78,572
South Puget Sound, WA
I used a left hand bit when drilling out the frozen bolts on the F602. It's a pretty slick trick.
Cast iron is not hard to tap if you drill in straight and slightly undersized. All you are doing it cleaning up the threads with the tap. Be sure to get a flat-bottom tap for this.
