The cat isn't burning like it should in my BIL's Fireview, due (I'm fairly sure) to the bypass door gasket leaking, and not as much smoke going through the cat to get converted to heat. The output of the stove is weak, compared to what it should be. I know, since it used to be my stove. Sure, I could do like the OP and open the air to 80-100% and get some heat out of it, but I'd be loading the stove every few hours. And even though the stove top might be within temp spec as the OP claims his stove is, I would be subjecting the interior parts to excessive flame heat and it would end up like his Fireview did, warped and destroyed. If he ran his Fv for 24 years and only replaced the cat once, I assume his cat wasn't working most of the time and he was running the air high and the flame big, just to get some heat out of it. He probably should have gotten a tube stove, not another cat.
I certainly wouldn't want to do all the work required to run a stove at 80-100% air, burn three times as much wood and load the stove three times as often but if that's what you like to do, have at it.
![Confused :confused: :confused:](/talk/styles/default/xenforo/smileys/confused.gif)
Most people run their stoves on low air, and heat their homes just fine. My normal air setting is .5 on a scale of 4, or about 12%. Later when it's down to coals, I might open the air to 25% for a couple hours. I get 8-12 hrs. on a load, depending how much heat I need.
I'm pretty sure that of all the people that read this thread, exactly zero of them are going to adopt his methods of operation. It certainly has been an entertaining read, though.
