I quoted it from your earlier post which has now been edited. Who made this statement then?The statement attributed to me is not mine. I don't know who made it.
+Do you want help getting your stove to work properly? If not that's fine but don't advise others this is a good or safe way to run a stove.
No, this is not what we have referred to as “draft”. That’s the primarily air control which everyone here is familiar with. We have been asking if you’ve ever measured the draft of your chimney..
I did. https://www.hearth.com/talk/threads/progress-hybrid.173698/page-3#post-2333249Who made this statement then?
I have no clue what you're referring to.
Well, he only brushes once a year, and gets 2 gallons of creosote, which would no doubt be much less with the cat installed. Adding to that is the fact that he runs an un-insulated liner. He might get away with it, but it's not exactly safe.Ok... I'll bite... why is it not safe ?
So the secondary burns when the bypass is closed or open?See the flow path here
http://blog.woodstove.com/search/label/Progress Hybrid
Still though, are you controlling the stove with the stove air control or the damper in your stove pipe? I'm not trying to start a fight and I'm happy you have solved the cat Ignition issue. It still isn't clear to me with what you are controlling the stove.
I have a PH that is 1 1/2 years old. I have 2 combusters so I can rotate each month.I did this with my 2008 fireview as well. After reading TJL's problems and running his stove without the combuster, I thought I would give it a try. I didn't have combuster problems, I just thought simpler is better. It is a hybrid. So I have been running it without the combuster installed for about a week. Before this, my combuster would load up in about 2 weeks and I would have to change it out. The stove heats up faster, burns are about 10 to 25% (worst case so far) shorter depending on how open I have the control lever.
Usually I put in 3 Enviro Bricks and open the control halfway until they light off. I then close the control until it is open about 1/8 of an inch. I have a chimney damper and I close that half way after the chimney temp is around 300.
The stove gets to around 450 in about 30 minutes from 250. Only 3 bricks in the stove. With the combuster installed, the stove would only get to 400 without the chimney damper on.
Anyway, I am liking this setup so far. The more bricks I put in the more heat. They are very dry.
If I use regular firewood, 3 or 4 pieces which fills the stove about half way, I get the same performance heat output wise, but the fire lasts a lot longer.
One ton of these bricks lasts 30 days + or - a few days .
I close the bypass so I can get the max heat from the stove.
I called Woodstock and asked if there would be a problem doing this and they would only tell me the stove is designed to be used with the combuster. I could not get them to say it may or may not be ok.
I have a double insulated 6" x 18' chimney. Half of my inside pipe is 6" insulated.
Outside air kit. I reduced the 5" adapter to 4" and cut and taped the 4" hose around my 3" pipe that I had when I has the Blazeking Princess.
My previous stove was a 2015 Jotul Firelight 600. Great stove. I really liked the screen option.
So I noticed that the PH burns almost the same as my Jotul did without the combuster installed. Time will tell.
I do not have anything against running a combuster, I just don't like the tear down every two weeks.
By the way, last year I ran 2 tons of the bricks through the stove and the cat never plugged and there was only a light coating of dust.
Yet you have never measured your draft so you have no idea if you could benefit from one or not.I do not have a stovepipe damper, only the damper on the stove. Although irrelevant to me, it seems a stovepipe damper creates the potential for positive pressure in the stove which could release smoke into the room.
Have you measured your draft? Have you measured the moisture content of your wood?I have a PH that is 1 1/2 years old. I have 2 combusters so I can rotate each month.I did this with my 2008 fireview as well. After reading TJL's problems and running his stove without the combuster, I thought I would give it a try. I didn't have combuster problems, I just thought simpler is better. It is a hybrid. So I have been running it without the combuster installed for about a week. Before this, my combuster would load up in about 2 weeks and I would have to change it out. The stove heats up faster, burns are about 10 to 25% (worst case so far) shorter depending on how open I have the control lever.
It sounds like he has too much draft and even with the stove air controls turned the way down, the always open secondary air inlet is allowing too much air and that's causing the cat plugging issue. Perhaps a stove pipe damper or a non hybrid stove would help this situation.Yet you have never measured your draft so you have no idea if you could benefit from one or not.
Yes a if that is the case a damper would help. And a non hybrid would solve the problem of clogged cats but there would be other issues depending upon how strong the draft is..It sounds like he has too much draft and even with the stove air controls turned the way down, the always open secondary air inlet is allowing too much air and that's causing the cat plugging issue. Perhaps a stove pipe damper or a non hybrid stove would help this situation.
Glad you got 'er running good, that's great news!A Major Breakthrough
Conclusion: My issues were caused by a cat that would not ignite due to surface deposits not removed by brushing. This was resolved by washing the cat per Woodstock the recommended procedure.
![[Hearth.com] Progress Hybrid [Hearth.com] Progress Hybrid](https://www.hearth.com/talk/data/attachments/239/239165-3ffab2dd419643219cf33b292700b410.jpg?hash=XAFAAuTWF2)
I don't think you could ever get positive pressure in the fire box, just less negative pressure, especially with your stack height. The pipe dampers have holes in them and there is also clearance around the edge between the damper and the pipe, so it is far from a complete seal.I do not have a stovepipe damper, only the damper on the stove....it seems a stovepipe damper creates the potential for positive pressure in the stove which could release smoke into the room.
![[Hearth.com] Progress Hybrid [Hearth.com] Progress Hybrid](https://www.hearth.com/talk/data/attachments/239/239167-16dfa479d05d544a3cd2a0db55c2f4e1.jpg?hash=t54l9UgDKc)
Right. It says in the manual something to the effect that it is "a violation of federal law to operate without the cat." Plus as you have seen, it deposits more creo in the pipe, increasing the chance of a chimney fire. They are never going to condone operating the stove like that.I don't think you should be surprised by this response. Woodstock has potential liability issues.
For this reason, I'm kind of particular about engaging the cat. I get the stove hot enough so that when I close the bypass, that cat is glowing in less than a minute. I understand that you can't see the cat on the PH but there's a provision for installing a cat probe thermometer, correct? If the cat is lighting when you close the bypass, that probe meter should begin to rise quickly, in a short amount of time.
For me to know when it's time to throw the bypass lever, I use a magnetic surface flue thermometer, rather than going by stove top temp. The temp on the stone top is slow to react, and the flue meter gives me more immediate information as to what is happening in the fire box. So I run the flue meter up to "X" temperature (safe temp where the pipe doesn't overheat,) then cut the air to hold it there for maybe 10-15 minutes, depending on how hot the stove is when I reload. Then I know that the cat will light pretty much instantly when I close the bypass, even though the stove top might only be at 150, as opposed to the 250 that is referenced in my manual. The sooner I can close the bypass, light the cat and get the stove cruising, the less wood I burn up in the process and the longer the load will go. You would have to experiment to determine what your flue temp needs to be, how long you need to level off there etc, to find out where the cat will light instantly when you close the bypass. Obviously, you also need to get enough of the load burning as well..
Woodstock has explicitly said to not run the stove without the cat. It's not safe. I'll see if I can find the post from Woodstock but this has been discussed a few times.
Hat I keep trying to tell you is that to me it sounds like your chimney may be creating to much draft. So even when you shut the air not the damper all the way back there may be to much suction and that is what is causing your clogging. I have been doing this a long time and have seen it with cat stoves many times. You need to test the draft at high burn if you want to solve your issues.I am pretty much on the same page as you. I have two surface thermometers, one mounted 10" above the ring on the vertical pipe (per Woodstock manual), a second on the stovetop above where the cat is located. The Woodstock manual indicates OK to engage the cat when the pipe temp reaches 300. That is what I do, along with cutting the damper back. Although I can't see the cat, I use an IR Thermometer to read the stovetop temps at the locations of the cat inlet and the cat outlet. With the bypass open the temp difference is maybe 10 deg. With the bypass closed and the cat activated, the difference is 50-80, depending on how much smoke is being burned. This tells me the cat is working. Other language in the Woodstock manual is a tad confusing about when to engage the cat. If for some reason I don't see the stovetop temp increasing, I know the cat is not ignited and repeat the process.
I control temp with the damper. Right now it has been fully closed for several hours. The room temp is 70, the outside temp is 30 and the stovetop is 460. If I need more heat output, I open the damper and possibly add more wood, keeping stove temps within recommended limits. Thus far, my stove is running like a Swiss watch, but it has only been a short while. What remains to be seen is if my chronic cat plugging issue has been resolved. I think it will since i only seem to need to move the damper between 0-20%. No high draft settings to entrain dust. At the end of a burn, I also rake the ash into the bin before loading more wood. This should also help minimize entrainment. I see no value in monitoring and controlling draft in terms of differential pressure. If the stove is running well, I either need more heat, less heat, or the same heat. It 's not that hard. Thanks for your confirmation that I'm on the right track.
