I've done it. Temps at >1100. Sphincter puckering, but effective. Good luck throwing baking soda on an inferno like that. You're going to have to open the door either way.
Have you tried it, or just assuming, because what you said makes intuitive sense to you?
A historical analogy: Millions of people have died of dehydration, from dysentery, flu, etc., because it makes intuitive sense to fix the symptom (diarrhea), by limiting the intake of fluids. We finally figured out, at least in the first world, bad idea.
I don't have your stove or setup, so I can't claim that I have experienced what you described. I am curious if you are making your judgement based on actual experience or what you are imagining what would happen if you opened the door.
Trust me, if I could have throttled it down enough to immediately shut it out, I'd have done it. And I wasn't too worried the house was gonna burn down, but
Great anecdotes, Dix. Ever figure out what happened on the first one, to get you to 1000? If you could go back, would you be willing to open the door to cool down? If not, why?
A. You'd be guessing wrong.Ummm. I'm guessing you've never actually used a fire extinguisher to put out a fire.
Here's a You Tube video that you might be interested in watching, which has a couple of examples of extinguishing wood fires.
I would imagine such a fire extinguisher would snuff out a fire in a wood stove almost instantly I'm GUESSING that throwing in a handful of baking soda would do pretty much the same, by impairing the ability of gasses and particles from burning. I suppose I oughta tery throwing some on a wood stove fire and reporting the results...
The kind of fire extinguisher in the video has a compressed inert gas fogging the fire with a powder which snuffs out the fire, much like throwing in baking soda will do. But feel free to use a fire extinguisher rather than baking soda if you prefer ---having both on hand is worthwhile.
My experience with fire extinguishers was being trained on putting out gas fires on broken utility gas mains with a fire extinguisher similar to that in the video. Amazingly effective, really. Takes only a second or two to put out a roaring gas flame burning thirty feet in the air. Direct the fire extinguisher jet of powder at the base of the flame, and as the powder rises on the column of flame, the flame is extinguished from bottom to top.
I've never put out a fire with a fire extinguisher outside that training, but I keep one not far from my wood stove where I can grab it and use it if need be.
The biggest disadvantage of using a fire extinguisher on a wood stove fire that I can think of, is that the fire extinguisher such as that in the video uses a fairly powerful jet of inert compressed gas to entrain the powder and carry it to the fire. blowing that into a wood stove might well cause hot coals to be blown out of the stove. and into the area surrounding the stove.
Throwing a handful of baking powder in the stove would avoid that issue.
B. How are you going to use it without opening the door again?
C. Baking soda would probably do just fine, IF you could get enough of it to the right place. Again, good luck with that. And again, not sure how you're doing that with the door closed.
Here's that video:
Oh, you'd have to open the door. The question is, what do you do then?
Here's that video:
Nice post. And a very meaningful warning to all:Scary as heck, but I open the doors wide to cool things down. I cannot completely close the air off with my Quad. My first time I tried and it just got more angry. I tried opening the doors but the heat was so crazy I closed the doors and sat with it. By the second time I had read on this forum about throwing the doors wide to cool things down. After thinking about it, it made sense. With the doors open you just had a regular old fire.
The second time, I suited up with a long sleeve sweatshirt, sunglasses, and a fire extinguisher at the ready. I opened the doors wide and the fire quickly settled down and the box started cooling. I'm a believer.
I still have that fleece sweatshirt with the hard crusty patch on the middle of the chest where it melted a bit from the initial blast of heat. It's a good reminder to avoid the situation in the future.
I'm gonna throw some baking soda on my next fire pit fire and see what happens. At the end of the fire. Hopeful that it extinguishes it, tuit de suite!
After reading some posts in this thread about running, calling 911 etc., my mind, for some reason, started thinking chimney fire which is different from an overfire.Reading this thread, I’m wondering about overfire in general - How does it happen? Can it happen on all stoves/are some stoves (i.e. cats, Woodstocks...) less likely to have this happen? Beyond damaging the stove from an overfire, what can happen that makes this so dangerous that it could cause a fire in your home? My last question comes up as I read some posts here of people saying if they saw an overfire they’d be calling the FD and gathering up their belongings to get out of the house...
I’m asking because while I have had moments where I forgot to turn the air down for a little too long and the stove got a bit higher than I’d like, I haven’t had a runaway stove (thankfully) that I couldn’ get back to a comfortable temp pretty quickly by turning down the air intake, and would like to avoid this scenario. The info here about ways to get an overfire under control is very helpful. Some general info about why and when this could happen in order to avoid, would be great!
All of this talk of extinguishers and bakings soda is great for chimney fires. But for a simple overfire simply opening the door works very well to bring the temps under control. Without having to shut down and clean the system after.
I’m asking because while I have had moments where I forgot to turn the air down for a little too long and the stove got a bit higher than I’d like, I haven’t had a runaway stove (thankfully) that I couldn’t get back to a comfortable temp pretty quickly by turning down the air intake, and would like to avoid this scenario. The info here about ways to get an overfire under control is very helpful. Some general info about why and when this could happen in order to avoid, would be great!
Make a video for us!
I think the pit fire will be much harder to extinguish with baking soda than a stove fire. The baking soda releases CO2 and displaces so much O2 that the fire poops out. This is a much better strategy in a closed box like a stove than in the wide open air.
It would possibly work better outside on a very calm day with no wind moving the heavier CO2 away.
Baking Soda is Sodium Bicarbonate NaHCO3. When heated it brakes down and CO2 is released. NaHCO3>NaOH + CO2Hmmm. I didn't know that baking soda released CO2 when burned.
I'm working up my nerve to throw some in, perhaps when a fire is burning normally and not too big to see what happens.
I'm also wondering if I will see a plume of white baking soda coming out the chimney, like a spouting whale!
