Agreed. But we have ways around it even with a sloppy flue collar.With good pipe and a good stove collar it should not be a problem.
That's not bad looking. A bit like an air filter cover on a carbureted 66 Impala but interesting and it doesn't seem to be subject to the kinds of problems one might have with one that spins. Would love to know more about how well it works. Will research it.Here is one that a person on the other site raved about. He said it improved the performance of his stove dramatically. He lives on the shoreline of a windy bay. I have no personal experience with it.
StormShield Model STS
Was just looking at it online. Seems to be to protect from wind and rain. Not sure that it would increase draft. Does anyone know. Looks like a variation on the vacu stack.That's not bad looking. A bit like an air filter cover on a carbureted 66 Impala but interesting and it doesn't seem to be subject to the kinds of problems one might have with one that spins. Would love to know more about how well it works. Will research it.
our weather recently, and for much of the winter, has been the kind that makes for crappy drafting. This damp, 50 degree weather makes stoves extra temperamental.
Webby, here are some photos. First is of the whole run from stove to ceiling. Then of the collar, the connection between the top and bottom sections and then the plate at the ceiling. Let me know if this is what you were looking for. (Sorry they're rotated; I'm obviously incompetent with a phone camera.) [By the way, the splotchy paint is my fault; touched up with the wrong tone of black stovebright. Will fix next summer.]Is like to see the stove pipe, from the stove to the box. Especially the stove pipe adaptor.
I used furnace cement on my DVL appliance adapter. The collar on my BK stove was a mess, not round with welds screwing up the fit. After grinding the welds down it seemed to improve the fit but still far from perfect.
Would you have a link to one you would recommend? I looked up the one you mentioned earlier but it appeared to be an adaptor to go into the box on the ceiling.I'm highly suspect of that stovetop adaptor, or whatever has been used there. Something just looks funky about it.
Yes, fans are off. It gets worse when the fans are on. Blows the smoke into the room.You need to use the one that's made for your pipe. You could have the correct one? It just looks odd, why is it a different color? Also, are your fans off when you notice the smoke smell?
If the top is off, does it look like that adaptor is seated good on the flue collar? Is the adaptor double wall like the rest of the pipe? It should have a label one it.Yes, fans are off. It gets worse when the fans are on. Blows the smoke into the room.
Will find out.If the top is off, does it look like that adaptor is seated good on the flue collar? Is the adaptor double wall like the rest of the pipe? It should have a label one it.
The dealer's guy is out here now. He says the adaptor is seated good, that it is double wall and he showed me the label. Says the pipe is Selkirk and so is the adaptor. Says nothing can be done about the screw holes because they're not in the adaptor but the pipe that sits on top. There's no section of pipe specifically designed to mate to the adaptor without the screw holes and he says there are no screws short enough to go in without piercing the inner stainless liner and creating more holes for smoke to escape.If the top is off, does it look like that adaptor is seated good on the flue collar? Is the adaptor double wall like the rest of the pipe? It should have a label one it.
The OAK wasn't blocked but the stove does appear to be running better without it. This is all very preliminary. Still checking it out and will have to do so under different atmospheric conditions. But it's running well at a lower t-stat setting with less smoke coming out the chimney. Trying to throttle it down so there's no fire in the box and see if it runs smoke free. Will have to see if it helps with the smoke in the house. For that, I'll need my wife's nose and maybe a week or two.Has inspected both the flue and OAK for blockage? Can he measure the draft?
