I've held off. Crocuses are in full bloom and daffodils are starting to open up. This is early, even for us.
It's not funny
So they just jammed the end of that pipe into the air intake vice using the proper connector? I wonder how closed off that was when it was in the intake? It might have been restricting the air going in the intake enough to cause some of the issues.
Then why in the H3LL do you have a wood stove? You have what, 6 days below freezing? LOLI've held off. Crocuses are in full bloom and daffodils are starting to open up. This is early, even for us.
I don't think that fitting is restrictive nor the problem. The 90 degree turn in the outside air duct would restrict air intake more. As noted, the location of the OAK intake is much more likely the primary issue.
How are humidity levels in your house?
If not high (high would be rare in winter), you might not (likely won't) have to run exhaust fans at all this time of year. We have an HRV, and it doesn't run at all, all winter. Don't have any other exhaust fans. Our house is fairly tight, but the winter time stack effect might be moving enough air through your house without needing anything else. Actually if there is enough of a stack effect, it might also hinder chimney draft too.
Dennis? There are no binders in HomeFires. They and Northern Idaho Energy Logs are formed with precision dies under incredibly high pressure. Heat releases the natural lignens in the wood bind them.Begreen, you did a review a while back on homefire logs: (https://www.hearth.com/talk/wiki/home-fire-prest-logs/). Dennis thought they might not be safe to burn (in terms of possibly damaging the cat), not knowing what additives or binders might be used. Did you have a chance to analyze them? Clayton, the owner, swears they're just held together under high pressure with zero additives. Do you have any sense of this?
I hear you. I knew something was up when I had my dog down at the lake for a swim and there was a bunch of kids swimming along side of him.... This was a couple weeks ago back in January.Winters like this concern me. I don't want my cold and dank little paradise to turn into Anaheim.
I know... I'm just reporting what I witnessed, it was a warmish Sunday, low 60's, and there were some children swimming Lake Washington, goggles and all, while their parents watched.It's not that warm.
Not sure who's crazier -- the parents or the kids.I know... I'm just reporting what I witnessed, it was a warmish Sunday, low 60's, and there were some children swimming Lake Washington, goggles and all, while their parents watched.
Pretty sure his name is Dennis. Out of the Penticton, B.C. office.Dennis? There are no binders in HomeFires. They and Northern Idaho Energy Logs are formed with precision dies under incredibly high pressure. Heat releases the natural lignens in the wood bind them.
I know it sounds crazy, but honestly it really wasn't. It was a very nice day, and I was even thinking to myself that if I had my bathing suit I for sure would have waded in a bit. The park was packed, and there were lots of people down by the water which was really not that cold, a few kids splashing around didn't seem out of the ordinary at all... until I rememberred it was January.Not sure who's crazier -- the parents or the kids.
