She's alright with burning wood (and eating meat) as long as she doesn't have to witness the necessary murder.You'd better put some foil over your stove glass - wouldn't want her to see what's happening in there and have a breakdown![]()
I feel for you. This is where a first rate dealer is worth his or her weight in gold. In lieu of that it's great to have BK checking it out.
That could be an issue. IIRC Highbeam had excess smoke by loading a lot more logs than recommended. Perhaps they are outgassing rapidly and overwhelming the cat?
Good to hear there is progress. Ask too about the quantity of pressed logs being burned. These logs outgas rapidly when hot. I'm wondering if too many are overwhelming the cat. As far as the hole in the pipe for draft testing, a probe thermometer can fill it or worst case scenario a black screw.Today, I got a message this morning from one of the Blaze King guys in Canada. Couldn't reach him but his message was, essentially, "Don't worry. We'll take care of you."
Gotta love a company that stands behind its products and its customers. Later in the day, I got a message from Chris (BKVP). He's out of the country but we were e-mailing. He spoke of possibly having the stove shipped to Walla Walla so they could test it. Then the dealer called. We agreed we need to test everything regarding the install and any mistakes I may be making before shipping the stove back because it seems to both of us very unlikely that the stove itself is at fault. On Friday morning, he's coming out to put my fan kit back on (the blades on the old one had partly melted -- an actual defect in the stove, or at least an accessory). While he's out here, he's going to disconnect the OAK. I'll run it with a window cracked, both before and after he detaches the OAK. We're looking for ways in which air pressure may be influencing things.
I spoke to him about measuring draft. He said it would require putting a hole in the stove pipe. I wouldn't mind if that could be the same hole for a flue probe. But he was lukewarm about adding an extra hole when our issue is gas leaking out somewhere. We'll cross that bridge if the OAK investigation doesn't lead to an answer.
Unfortunately my stove guy wouldn't know. He's a good fella, really stands behind his work. But it's a heating and cooling company; they deal with much more than wood stoves and he doesn't personally burn. I'm still glad I went with him. But it is a challenge figuring out problems like this.Good to hear there is progress. Ask too about the quantity of pressed logs being burned. These logs outgas rapidly when hot. I'm wondering if too many are overwhelming the cat. As far as the hole in the pipe for draft testing, a probe thermometer can fill it or worst case scenario a black screw.
I don't understand why it can be better at times and worse at others.
Makes it hard to find the problem. We'll see how things go on Friday after the OAK is disconnected. Does the stove need to be cold for this to happen? I'd love to watch the effect on the fire when it comes off (if possible).This could be due to the size, rate and stage of the burn as it relates both to your operation (adjusting air supply) and to your flue system (poor draft and/or partly obstructed), not to mention weather conditions. Lots of variables interacting means variable outcomes with each burn.
I haven't been keeping up with this entire thread, I have a few thoughts:
My glass is never that dirty, ever.
I also was having some issues with the cat stalling. It would almost go out if I went under 2 with the air control. I moved the Ashford to my 8" flue in my front room, since the move it has acted like a different stove. It runs like its intended to now that it has better draft. Both flues are the same height and straight up, no elbows. The only difference is the 8" flue.
You are suffering from poor draft.
A vacu-stack will work if down drafts are your problem, it won't help with negative pressure issues so much. I have also found that they clog very easily with a BK, it would be a last resort in my opinion. I'm Not recommending an 8" flue either, it's just odd that it worked for me. Maybe it has something to do with your location and climate? I can see my stoves struggle when a low pressure system rolls in, it's uncommon here, but not for your area I'm guessing?Webby, since going to an 8" flue isn't an option (unless I'm going to spend a heck of a lot to replace what was just installed last spring), what are some ways of dealing with inadequate draft? Does the vacu-stack work? Looks like they're only around $100 bucks. My preference would be to avoid anything electric.
So no suggestions?A vacu-stack will work if down drafts are your problem, it won't help with negative pressure issues so much. I have also found that they clog very easily with a BK, it would be a last resort in my opinion. I'm Not recommending an 8" flue either, it's just odd that it worked for me. Maybe it has something to do with your location and climate? I can see my stoves struggle when a low pressure system rolls in, it's uncommon here, but not for your area I'm guessing?
Test the draft. Once won't do it though, you said its intermittent.So no suggestions?
So no suggestions?
