I'm glad that I moved the snow from the east side of the new garage yesterday. Today I removed slush and water from different areas near the house and the new garage, I also scraped down the driveway.
I'll take the driveway down to whatever mother nature allows and then ash & sand. Next to the garage will get another couple of swipes with the snowplow before it freezes so I guess the answer is yes.Do you level off / plane the ice area's off before a re-freeze? This year has to be a pia with the freeze thaw cycle.
With the rain we received overnight, the snow came off the garage roof so I took care of that.
We had a new coating of ice overnight so I was back putting ashes and sand on it again today.Your rink is looking good. Looks about the same as mine.
Hope you all have had a nice holiday and good 2019 so far. Been busy her with a bathroom addition.
Sounds like our forecast as well. I didn't not anticipate so much ice and so many freeze thaw cycles for a Maine winter.We had a new coating of ice overnight so I was back putting ashes and sand on it again today.
Thanks @Hammy , I hope you and your family have a good and safe 2019. How's the bathroom project going?
Our temp is at 35 tonight with it in the low 40's tomorrow morning, we could be in for some wind gust in the mid 40's tomorrow but by then all the ice should be off the trees.
It seems like this is the new norm for our winters up here. We always have three or four full garbage cans full of ashes we use for the majority of the driveway with sand getting used closer to the house.Sounds like our forecast as well. I didn't not anticipate so much ice and so many freeze thaw cycles for a Maine winter.
We've been thinking about a nice pull behind sander for the rhino or a 3 pt. sander for the tractor.
I already have chains for the rhino (not on yet) but so far without the chains it hasn't had any problems with the ice. The tractor has never had a problem but without chains if I ever started to slide in certain areas, I don't think that I could stop it once it starting sliding.I've been thinking about a sander for my Ram 3500. This way I don't have to swap implements as much.
Well, Kioti discontinued everything DK except the SE, so I'm going HST. They can also spec the DK4710SE on the lot with the cruise control and linked pedal for not many more dollars. I liquidated some assets so I'm waiting on a check and then after it clears the bank I can go pick up the tractor. With incentives the tractor is a pretty good deal and will do everything I need of it. I really wanted the hydraulic shuttle shift, but they sold their last one, and even if Kioti still made them, it would have been just as expensive to get one ordered. The dealer also said the HST has less than 20% power loss, but I don't know if I believe that. Maybe Kioti is more conservative in their power ratings like VW with the GTI.
I think you will like the HST. Congrats on the new tractor.
With the high wind gust today, I decided it was a good day to grease and check all the fluids, all is good.
I don't have it quite yet, waiting for a check to clear at the bank. I'm hoping another week or two. I already put a hold on the Tractor.
Yes I do, I bought it late in the fall of 2018. It makes greasing the tractor real easy but there are two spots out of three that the locknlube won;t fit so I use the old grease gun.Do you have a locknlube? That and my cheapo air grease gun make greasing about as easy as can be. I got the locknlube for Christmas and used for the first time the other day. Love it.
Just a question on a Mahindra HST, if you're going forward do you need to stop before going in reverse?
Thanks @Hammy. It looks like we might get between 8 - 12 inches of snow Tuesday through Wednesday, the 4540 will get some work.I just take my foot off the forward pedal then press the reverse pedal. I never really thought about it but I guess I would be at a stop before I press the reverse. I have only ever used the brake/clutch to put the parking brake on. Once you take your foot off the direction pedal the tractor pretty much stops as quick as using a brake.
This will cover the ice until the next melt, it's very dangerous if you want to take a walk.Do you level off / plane the ice area's off before a re-freeze? This year has to be a pia with the freeze thaw cycle.
