Ashful
Ashful if at the end of the day if it all goes to chit and my engine woes persist I would consider buying your 675e at the right price if you were still interested. Just out of curiosity what engine did you upgrade to? Vertical or horizontal? And what GPM pump did you upgrade to to get that reduced cycle time?
I upgraded to an Intek 344cc vertical shaft, as I required at least 300 cc to drive a 16 GPM pump at the speed and pressure I was aiming to hit, and that was the only vertical shaft engine I could find above 300cc that would nicely fit onto that splitter frame. It works great, but being a cheaply-engineered Briggs, the intake noise is intolerable. Unfortunately, the vertical shaft Honda was too tall, where I feared it might get in the way.
My current cycle time is somewhere in the 8 second range, at a full 22 tons splitting force. I’d have preferred to go 22 GPM, and get my cycle time down around 6 seconds, but that would have required a custom cylinder with larger ports and more modifications to the reservoir on the splitter frame. So, for the sake of simplicity, 16 GPM / 8 seconds is where it’s at.
I kept the 675e, because I also have a pressure washer that uses the same engine. So, I’m not really anxious to sell it, I only offered it because I thought you were in a jam, and needed an engine. If that’s the case, I’d still let it go, but if you’ve found a better option I’ll just keep it in case the pressure washer goes kaput.
