Backwoods Savage said:Gyprat, do you have the ceramic or steel cat?
Gyprat said:Backwoods Savage said:Gyprat, do you have the ceramic or steel cat?
Steel cat.
I used some stove cement on the chimney joints.
Just got off the phone with Woodstock. They are sending a new combustor. The guy I talked to said they never had any problems with new catalytic converters. He also mentioned that new steel combustors are much better than the ceramic ones and they should last longer.
Stump_Branch said:Ive heard of this once, but the persons air control lever wasnt set right, it had come undone from the actual shutter. Maybe take a peak at that.
Do you know what your stack temps are? Ive found knowing this helps me adjust the air control better than just a stove top thermo. At least with the soapstone anyhow.
Backwoods Savage said:Here is what we would like to know:
1. When was this wood purchased?
2. What type of wood is this?
3. When does the supplier say this wood was split; not cut, but split and stacked.
4. How did you handle the wood after receiving it? Stacked outdoors? Indoors?
5. What was the weather like when you tried running the stove. Temperature? Stormy? Windy? etc.
Gyprat said:Backwoods Savage said:Here is what we would like to know:
1. This wood was purchased 2 month ago. Moisture reads anywhere from 10 - 20%. Right now I only burn the most seasoned (<15 %) pieces.
2. Mostly oak
3. He says it was split last fall
4. It's stacked outside covered on top. I put two treated 2x4's on the ground and stack wood on top of it. The stack is 8' long x 5' high. I also tried store purchased, kiln dried wood. Same result. My neighbor has a Keystone stove, I got some of his wood and it made no difference. He has no problem getting his stove to temperature.
5. Last night it got down to 27 degrees, no wind.
P.S. Thanks everybody for trying to help me. Maybe I'm just expecting too much from this stove....
Den said:. . .and the Ozzies hit back with a wicked left hook. At 22", they have the longer reach, but what about the legs? Can they go the distance? Will they still be standing after 12 hours, or will they be knocked out cold?![]()
2. Mostly oak
Stump_Branch said:This appears to be a fuel issue as backwoods stated. Btu's will be stolen to boil off any moisture rather than go to useable heat.
To be honest, once the cat is lit it jump up to 400 pretty quick, then slows down as it works its way up too and past 500. After a steel tube stove, a cast tube stove, and a soapstone cat stove, i think the cats are but a bit easier to run. Really. I say this because its easier to get to and stay in the cruising mode, rather than adjusting the air in stages constantly to get and keep secondaries.
Its different than a car where more throttle means go faster. Stoves to a point, the less air in, less out, more heat stays in the stove. Has taken me time to learn this.
Gyprat, try and mix in lumber scraps with your current cord wood, dont do a full load of lumber. And no pressure treated wood either. You should see that you can burn at a lower air setting, such as 1. This should help you get up to temps. If not maybe we can rule out the fuel issue.
Best of luck.
firefighterjake said:Stump_Branch said:This appears to be a fuel issue as backwoods stated. Btu's will be stolen to boil off any moisture rather than go to useable heat.
Best of luck.
Not saying that the cat stove with its "set it and forget it" flip to the cat isn't the cat's meow because it is appealing . . . but I am wondering about fiddling around constantly to get and keep the secondaries . . . I mean with my Oslo once it's up to temp I generally kick it back to the halfway mark, let it settle down at that temp for 10 minutes or so and then kick it back to the quarter mark and let it settle . . . if it's been running for a while I'll often then kick it all the way "shut" . . . a little more fiddling, but once at the quarter or "closed" mark there is no more messing around with the air control as it goes through the burning cycle.
2. Mostly oak
Backwoods Savage said:Yes indeed. Woodstock is second to none in the customer service area and yes, they do work the phones on Saturdays. Glad this has worked out Gyprat. Enjoy.
Backwoods Savage said:Not sure on that but I doubt it. Realize the name of the company is Woodstock Soapstone Company.
