Figured I'd start a new thread based on experience dealing with some issues on my new Jotul Oslo F500 v3. I was previously the owner of a Jotul Firelight 12 for the last 15 years (it did the job nicely, but was getting old). I live near Concord, NH. My dealer is Abundant Life in Chichester, NH.
There seemed to be an obvious air leak when I first started using the new stove about a month ago, The fire would not subside and at best I could get a 2-3 hour fierce burn. In addition, it took Herculean strength to latch the main door.
Caveat: When addressing a wood stove issue, it is always humbling to not be knocked down by variables like dryness of wood and health of the chimney. I had to get my gander up and assume those two factors are relatively "normal" for me.
To start, of course, I went to Heath.com and read related posts. Some very helpful ones were:
My raw feeling is that Jotul, as a Maine manufacturer, has some quality control (QC) issues. I am not sure I would recommend purchasing a Jotul at this point as my issues are raw, but my thinking may evolve. The F500 Oslo v3 may be a good product for the long-term, but the short-term experience has been weak (Abundant Life, the dealer, was great).
I will update in the future. Hope this post helps others in the same or similar boat.
- This post clearly showed two holes on the left and right side of the ash tray cavity (installed by Jotul to meet government standards)
- This post described poor quality control around gaskets and inspecting units
- The easiest to address was the door issue as it is acknowledged and common. Jotul has a fix involving a new latch and set of shims. It came in a small package. The factory instructions, despite being simple, were slightly off - but the fix was easily done. Abundant Life was very helpful.
- The next fix was likewise easy. I followed the post's guidance and went to Harbor Freight and bought a set of $2.95 magnets. I used a nickel-sized one on each side and covered the left and right air holes in the ash tray cavity. I did notice a slight different as the fire was a bit more controllable, but certainly not there yet. This issue, POSSIBLY stemming for a need to meet government standards, is sort of devious.
- The burn issue was more complicated and work is ongoing to resolve. After doing the dollar bill test (this video was done with the replacement door), it was evident that the ash door, which I suspected, was not sealing correctly despite the new factory installed gasket (which I perceived was sloppily installed). Paul, the service manager at Abundant Life, was terrific. He put a new gasket on it and I took it home to try; unfortunately the problem was still there. I went back and Paul affirmed the issue using a floor model. He sent me home with the floor model's ash door to try and that made a BIG improvement. The next day, after a 7 hour overnight burn - I STILL had embers (first time) which was a huge positive turn. As we looked at the original door, it was evident that it should never have passed quality inspection in terms of its cast mold and gasket. Disappointing.
- Lastly the pin that holds the ash door to the frame has issues. Likewise, lack of quality build/control. The pin should "just" slide in. It does not and Paul is ordering a new pin.
