Here’s a similar load from last night comparing the temps from before and after the pea gravel. There seems to be quite a dip in flue temps compared to before.1.5 hours in, turned down to low.
View attachment 323021 View attachment 323022 View attachment 323023
I had the rear heat shield and bottom heat shield off since last year. The only difference is the pea gravel in the side shields this year.So sounds like the removal of the rear heat shield sheds more heat from the f45's exhaust than the added pea gravel's affect of raising firebox temp.
Actually that does not make a much sense though?
What do you think is going on there?
Well I think that’s the way it’s supposed to be? My previous wood stoves ( Keystone, Fireview and BK Princess) all were like that.Hmmm. Hard to comprehend that higher stovetop temps co exist with colder flue temps.
I'm perplexed.
ok so with higher stove top temps and assuming higher internal temps , the f45 is probably drawing more air thru the stove which could account for the flue temps being cooler. The fire and secondaries flames and coal heat has direct paths to the stovetop and sides.Well I think that’s the way it’s supposed to be? My previous wood stoves ( Keystone, Fireview and BK Princess) all were like that.
I’m just surprised my flue temps dropped this much from last year because of this mod. It must of made the heat transfer efficiency better somehow? I’ll take it, more radiant heat is better for my open floor plan and high ceilings.
Both stove top and flue temps are good guides to what’s going on with your stove. I mostly monitor flue temps after reloading since they usually react faster than stove temps. Once I see flue temps get up to the 400 -500 range I’ll start backing down the air in stages and keep watching the temps and fire til I get the output I want. I like to keep the stove temp below 700 and mostly cruise in the 500-650 range and my internal flue temps are usually around 400-600 depending on the air setting and weather conditions affecting draft.I’m about to have my f45 installed in anchorage Alaska. House is Well insulated, Triple pane windows, chalet style home with about 1600 sf. Hoping I didn’t make a mistake not getting the f55. My question is…what is “normal” operating temp? Should I have a thermometer on the stove top, or on the pipe? Pretty excited about this, since I wanted a non-cat stove and this seemed to be the best option I could find. Anyone offering tips for operation? I’m going to burn well seasoned white birch.
Do you think the lower flue temps are due to removing the rear shield, allowing faster heat transfer from the firebox? If that's the case, removing the side shields should remove heat even faster, and drop flue temp even more, no?So far I have found the flue temps are lower than before. The other night the internal flue temps were running at 450 while the stove top temps were at 650. My thinking is without the shielding I’m getting more heat transfer through the stove and less up the chimney. Kind a like the difference between single and double wall stove pipe. More heat goes up the double wall.
No I had the rear and bottom heat shield off last year. The only difference this year is the pea gravel in the side shields. I thought about removing the side shields for testing but I wouldn’t like the look and I like the extra thermal mass.Do you think the lower flue temps are due to removing the rear shield, allowing faster heat transfer from the firebox? If that's the case, removing the side shields should remove heat even faster, and drop flue temp even more, no?
A little more radiant heat from the stove and the blocks.Todd, Besides the temp differences, what differences are you noticing with the pea gravel vs without.
It's the Fall Foliage Special! Don't miss out!!I was actually thinking of selling this stove for another Woodstock but thought I’d try this first. I don’t think I could justify $3k for a new stove but I always have my eyes open for a good deal.
If you find 2 Keystones let me knowJust bought a new John Deere with a snow blower so a new stove is out for now. Awhile back I went to a local dealer when the new Jotul F445 came out and the owner said he’d give me $2k for my F45 if I traded it in for the F445! That’s what I paid for it back in 2020! These stove prices have gone insane the last couple years. I wouldn’t mind finding a used Keystone though if I could do an even swap or come ahead. 😁
