carl spackler said:JJEGLBS said:Regarding the blower on auto or manual -- does anyone else find it difficult to remove the grate in front of the fans to change the blower setting and/or adjust the fan speed with the grate on? I think the blower speed switch was installed a little bit off because it rubs against the grates when I try to adjust the speed. Also, if I try to lift the grate up and out with the insert door closed it is difficult because the top of the grate hits against the door and I have to really push to do it. Not really critical problems -- more slight annoyances -- but, I might as well make adjustments if I can.
I don't need to remove the grate to use the fan switch.
perplexed said:carl spackler said:JJEGLBS said:Regarding the blower on auto or manual -- does anyone else find it difficult to remove the grate in front of the fans to change the blower setting and/or adjust the fan speed with the grate on? I think the blower speed switch was installed a little bit off because it rubs against the grates when I try to adjust the speed. Also, if I try to lift the grate up and out with the insert door closed it is difficult because the top of the grate hits against the door and I have to really push to do it. Not really critical problems -- more slight annoyances -- but, I might as well make adjustments if I can.
Ditto that. You might try positioning the controls so they are accessible through the grate. Easy for them to get knocked out of kilter.
If the adjustment knob for the blowers gets pushed on too tightly by somebody operating the insert it is hard to turn. Just has to be pulled out a bit and is easy after that.
I only remove the grate with the insert door open. Much easier to handle it that way.
Bizango1 said:Regarding secondary burning. How do I tell when that is occuring? Is it happening when the flames dance around on top of the wood and stretch up to the secondary air tubes? Also is there a link or an explanation of how the secondary air tubes work? Couldn't find anything on the Jotul site.
Thank you.
woodheat said:the holes should face forward. There is a small whole on the center top of the tube and there is a matching peg in the top baffle plate that should key into the hole on the tube. This keeps the tubes in place and will not allow them to turn or come out unless the baffel plate is lifted. Your baffle plate key must not be in the tube hole if the tubes are turning or falling out.
Thank you.
JJEGLBS said:While I was in there I also noticed that the fans sit freely on the bottom of the insert (i.e., I can move them around). They look like they have brackets on the top of them with small holes. Are the fans supposed to be attached to something in there?
Thanks so much! This site has been a great benefit, as has this thread!
JJEGLBS said:carl spackler said:JJEGLBS said:Regarding the blower on auto or manual -- does anyone else find it difficult to remove the grate in front of the fans to change the blower setting and/or adjust the fan speed with the grate on? I think the blower speed switch was installed a little bit off because it rubs against the grates when I try to adjust the speed. Also, if I try to lift the grate up and out with the insert door closed it is difficult because the top of the grate hits against the door and I have to really push to do it. Not really critical problems -- more slight annoyances -- but, I might as well make adjustments if I can.
I can't a finger between the grates to access the switch. Do you use something else to do it (like a pencil)?
carl spackler said:, I am barely getting 5-6 hr burns.
labrador said:I can't seem to get my stove to push the room temp above 66-68 degrees after running 4-5 hours. The room is 850 sq. ft. and the ceiling 8 ft. Wood is very dry. Also do you or any other owners of the 550 have to crack the door about one inch to start a good fire? I get an IR reading with the door open of about 700 and the magnetic one in the center of stove where hot air exits runs 375-400. I s this about the same for the rest of us? Thanks in advance for any advice or thoughts.
soxfan13 said:Labrador,
Perplexed, when you are getting longer burn times, are you keeping the fan on low? I like the fire so I reload the firebox more than I have to. I could probably go every five hours or so because the unit is still throwing heat but looking at just a bit of coals isn't that much fun. I have never gone more than 5 hours without reloading it yet. Just like everyone else, I am still trying new stuff with this unit.
