Seeing how this large stove is new I think there needs to be a ongoing thread about how to operate this popular insert.
As a complete n00b to wood burning I have found through 3 days of experience that stacking a few splits stacked high and keeping the throttle on about 1/2 to 1/4 gives a good secondary burn for a long time on relatively little wood. My wood so far is not seasoned that well, although I have yet to break into my main oak cord and a half that has been stacked in full sun all summer long.
Yesterday and last night I was able to keep the house in the upper 60's and even up to 71 or 72f despite dropping outside temps to 46 or so. The wife made me fire it up again early in the day but by choice I might not have done so. I am balancing trying to keep the wife happy and saving wood for when it gets really cold here in January-March. I adjusted the blower fan to about 1/2 speed all day. My plan is to try to drop oil burning use by 1/2 this year. We'll see. But tonight there is one more burn because temps are supposed to drop to 40 before weather heating up the rest of this week.
Also, I have been having a problem keeping the large glass area clean, I suppose because of my wood quality. I have cleaned it every day with newspaper and ash. Not fun. I hope I don't have to do this every day. For those Rockland burners with well seasoned wood I would be interested in hearing if you too have a clean glass problem.
I keep mine where the blower output is. That seems to be the most popular location. Here's a pic. Just ignore the mess. I was having issues with the furnace cement after I installed my block off plate.
I'm a newbie to the world of wood burning but I have some experience with construction. That was not furnace cement that you used on your flue connection. It was fireblock sealant, which is designed to seal penetrations in fire walls (wires, pipes) to keep fire from spreading too fast. This product isn't meant to be heated over and over again. It is intended to give people a little longer to escape in the event of a structure fire. I'm not sure what the correct product would be to seal the flue connection.
Without just turning the blower on full blast, what are you guys using to clean the dust out of the top of the firebox? You know, in between the shroud and firebox.
FYI, I bought my stove in 2009 and it only had the cast iron baffles.
As far as the air control, there are three bolts on the inside behind the intake, two on sides and one top middle. In my case, the air intake mod didnt help much with burn times.
The only thing i think you can oil is the bronze bearing on the end, its under that rubber red cap.
I clean with wd-40 if it has a little rust, or just a damp microfiber if its dusty
The air inlet for the doghouse is above the heat shield above the blowers, not easy to get to during normal operation. You can start by placing screws in the holes. size them so they just slide in, about an 1" or so. They wont come out
Yes, this stove loves to breath. In my setup i've found the doghouse to be beneficial when needing to get a stove going. Also, depending on the wood, i had too much coaling which would have burned down with the help of the doghouse air.The screws can be taken out in between burn cycles with heavy gloves and needle nose pliers. The screw need not fit tight. On my stove there are two doghouse holes, one is plugged with a loose fitting screw, not threaded. It basically just blocks the rocket booster effect and most of the air. I would experiment with that until your happy, then make more permanent solutions if you want.
You can see the inlet at just the right angle, but its best to take out the heat shield to see it.
