Jotul 8 - front grill not fitting?
circlefx
1
Maine
Hi folks,
just picked up a second one of these.. my first is in my home and we love it. This is the original with the spin draft on the front.
The second one we just purchased for my parents home and it was even cleaner than the one we got, but there is an issue.
When I put the log/ash retainer grill in place and try and close the door, the glass touches the grill just as the door is closing. We already had to replace the glass (expensive! $160!) because the first one cracked.
I'm pretty confident that internal baffles are all installed correctly and the bottom plate is sitting where it should.
Also, I compared the front grill in the new one to the one in my stove and they're identical.
What could be causing this lack of clearance!?
Stumped, in Maine.
Thanks!!
Is this the part?
[Hearth.com] Jotul 8 - front grill not fitting?
If this is the part it drops into place behind the two positioning bumps in the bottom burn plate. Make sure it is not backward.
Very common thing for log retainers of Jotuls to bow outward slightly (check stove burn temp too that can cause this bowing), people breaking glass mysteriously usually gets this issue noticed. Not a large space in between glass and log retainer when they aren't bowed. Worn gaskets in the door exasperates this problem too sometimes when the door is pulled even closer inward by the worn gasket. I've seen people break 2-3 pieces of glass on Jotul 3's before someone at the store realizing the problem, but can happen with 8's too... the retainer that BG has in the pix is upside down too fyi.
Bringing an old thread back to life. I have a 35 year old Jotul 8. It has been in great condition and has all it's original burn plates. I've seen a number of posts on the internet regarding warped burn plates, sometimes with photos, and they look really bad. I've always attributed these to the owners over-firing the stoves. Whenever I am doing a thorough cleaning and inspection of my stove's insides, I always think about how perfect those parts all look after so many years of pretty hard use. Anyway, just tonight I suddenly observed firelight passing through, under the bottom of my log retainer where it should be sitting flat on the bottom plate. Sure enough, it's warped. However it's not arching forward towards the door, but rather upwards ( a 90 degree difference). I am now really curious about the cause of this. Is it just a matter of cumulative heat exposure with age? After all, it's had 35 Seasons of hot fires. Or was it because I may have pushed it a bit harder lately? We've had quite a bit of cold weather lately and I have been keeping that stove running right at what I've always considered the upper limit, pretty much continuously over the past week or two. Yet I feel like I have done this a number of times over the years. I'd be curious to hear what the circumstances of other Jotul 8 log retainer failures were (or if people are still finding theirs in perfect condition after 35+ years). Anyway, the part number (101941) is clearly stamped on it, and using that, I was actually able to find a new one on the internet pretty quickly, although I won't believe it until I actually have it in my hands. I can't tell you how good it feels when you can get a new part for a 35 year friend like my Jotul 8.
Hey and great hearing an old Jotul girl is still doing her job. The internals can warp in any direction, outward inward upwards too. Its great to hear you can still get the part. Jotul guaranteed parts for 20 years after its production run ended, but lots of after market places too, a good Jotul part provider is Woodman's parts in NH. I'd suspect pushing the stove a little harder could've caused the quickening of degradation but after 35 seasons (100 cords plus probably), thats a lot of heat to come through that stove. Stove top thermometer is always your best friend to prevent overfiring (400-600 is ideal). Above 600 is tolerable but remember past a certain point of internal temperature, the stove's skin cannot absorb more heat to distribute to you, so it goes up the chimney, dropping efficiency of the burn. I've rambled enough, good to see an 8 doing its job still.
My new part came today. I actually did get it from Woodman's. Upon first inspection I got worried- it too has a bit of an upward arch. So I thought maybe I had just bought a part I didn't need (maybe the warping was on the base plate under it), but when I put the old and new part side by side, could see that the degree of arching was greater in the old part. Sure enough, when I put the new one in- it sits much better and only shows minimal gap beneath it. Otherwise it is identical to the old part. Exact same codes stamped on it, except for date. My old one says 04-90 and the new one 06-24. Yes, it is 34 years younger! I noticed that both have identical imperfections in them. I think they were cast from the same mold! Anyway, I always try to run my stove at about 450-500 degrees, sometimes it goes up to 600 but that's generally it. However I'm not measuring stove top, I measure from the flue. The stove itself is always cooler.
Attached are a photo of the old part and the new part. Note how you can see fire light under the old one but not under the new one. I can also rock the old one forward and backward, but the new one is more stable and won't rock.
No rambling on your part- all good info!
  • [Hearth.com] Jotul 8 - front grill not fitting?
Reactions: all night moe
So much for my enthusiasm over having a part made from the same mold- I was clearly wrong about this. I was always able to use my fire poker to lift the front piece by sticking it into the cutout in the middle front. Today I tried doing this with my new part and the poker wouldn't fit in. There were some distinctive marks on both the old piece and the new one that made them look like they could have come from the same mold, but I guess those marks are just a normal part of the manufacturing process and not mold-specific. We see what we want to see...
