Yes. Weird thing, before the green on/off light flashed when I turned it on. Now it doesn't.Ok will it stay running with the switch jumped?
Ok. But with pellets only, right? Also would I have been able to blow through the hose if it was clogged in the elbow?Let it run for half an hour then bump it to heat lvl 2 and see how its burning. I’m thinking the elbow that the hose hooks to in the firebox is plugged
And in the firebox, how much air/draft should I be able to feel up behind the burn bowl. I took it out and I could see a metal tube leading away from that area behind one of those exhaust slots. Should there have been noticible air flow when I feel there while the exhaust fan is on?
Oops, spoke too soon. My "big fire" just went out.no you couldn’t have blown through itduhh.
You wont feel a lot of air. It might hold a post it note.
Oh! You're at work! So sorry. Yes, thank you.Ok the proof of fire snap disc are somewhat fragile at the terminals where they connect to the body. If they get loose it could cause intermittent connections. But that only controls the convection blower. Is that coming on? So we still have a big draft issue. I’m going to dig a little more into the exhaust motor and control board when i get home from work. Cant read this fine print on the phone I’m old also![]()
So I'm going to have to stick a paper clip in there (that's how Ive been jumping these things) while the stove is plugged in? And that will stop the #3 blinky blinky and keep the convection fan on?Well if the stove is warm, and you a comfortable with jumping the low limit switch after the stove has turned on and in start up for 30 sec. this is live voltage 120vac. We can’t do the jump before because the board will see it as a err and shut down. If your not comfy with that it’s cool.
Ok that means you got it through the startup and now it's in run mode. what kinda noise did the convection fan make/ rattle squeal?
out of the manual
The Ignition Cycle works as follows: a. The Combustion Fan comes on at high speed and the control board checks to make sure the Vacuum switch locks in. (See section on Diagnostic features on page 34 and 35) b. If the Control Board senses the Vacuum switch the Exhaust Fan drops to a lower start up speed and the Room Fan shuts off. c. After 5 minutes the board starts feeding Fuel on the #1 setting until the board senses Proof of Fire or until the ignition cycle times out after 15 minutes. d. If the board fails to sense P.O.F. after 15 minutes it will shut down and flashes the #3 alarm. e. If the board senses P.O.F. the stove has started successfully and the Igniter shuts off. The unit is now in “Normal Operation Mode”. If the Stove went into “Shutdown” and the #3 LED is flashing repeat the Start-Up process. (See section on Diagnostic Features on page 34 and 35.) C
out of the manual
yes that's normal on a lot of stoves.. now i gotta ask, I was just reading the manual for your stove. Is your coal rake rod pushed in? under the door on the front of the stove there is 2 rods) The Coal Rake & the Slide-Out bottom must be in the correct position for the unit to operate correctly. The Coal Rake must be pulled out or the burn pot will overload. top rod out bottom inQuestion: is it normal to have a tiny gap around your heat exchanger tube scraper rod? I never noticed it until now when I have a fire in the fire box.
