JRemington
Put it on setting three and open the draft. The flame should be real active and you should have some sparks bouncing around. You don't want to see a lazy flame with dark or smoking tips on the flame.
Yes the slide.Ok. I am sure my half would know. But when you say open the draft.. do you mean damper if so all the way?
Yes the slide.
I just came back from a call and I'll tell you why I always tell people to open the draft first if the pot is filling and it's smoking. This couple have a dog as big as a cow. This is the second time he's push the draft lever in. If you're having a problem, opening the draft all the way takes that out of the equation. You can reset it after you find the problem. Which leads me to the second most common issue. People call and tell me their stove keeps shutting down right after they cleaned it. That's because they forget to lock the ash drawer. You did lock the ash drawer didn't you? You'd be surprised how many new stove owners do this.
Good stuf,glad you are here,and,being a technician,much appreciated.Her damper is behind the panel,have to remove the panel,but,if they keep it iI expect they will do the "rod through the side panel" conversion.I have seen so much pet hair clog up room fans it is crazy!I just came back from a call and I'll tell you why I always tell people to open the draft first if the pot is filling and it's smoking. This couple have a dog as big as a cow. This is the second time he's push the draft lever in. If you're having a problem, opening the draft all the way takes that out of the equation. You can reset it after you find the problem. Which leads me to the second most common issue. People call and tell me their stove keeps shutting down right after they cleaned it. That's because they forget to lock the ash drawer. You did lock the ash drawer didn't you? You'd be surprised how many new stove owners do this.
Nope all is coolBut it is a contained unit. There are no levers outside.
I think I must be having a truly blond moment View attachment 216732
Nope all is cool
I really would like to see that install be changed to 2 4 degree bends instead of the 90 degree bends,any stove would breathe better,but,wait till yer dealer shows up.
It is a 1/4 turn thumb latch,draws the ash pan up against the gasket,I cannot believe your husband would not have done that wrong.
OK I’m going to sound really stupid here I didn’t know there was a lock on the Astros we will look at our stove in detail tomorrow morning when it is bright out. We just shut the red drawer so it’s closed. I will ask the husband. He has been the one doing all of this. I will see if he has noticed any type of luck on the ash pot
nothing stupid about it. they should have walked you through an entire first fire. explained everything. and answer any questions you may have had before they packed up and left.
We may have just found your problem. It should be tripping your vacuum switch. But if it's not it's going to cause a combustion problem. I see you have cathedral ceilings. How far above the ceiling does the pipe go?
Those three elbows alone take up 15 feet of EVL. Add what looks like 3 feet of horizontal and 8 feet of vertical and you're at 22 of your 25 allowed. Two 45's instead would have you at 17.
