Help with new Enviro P3 stove
Thanks,and totally agree with everything you said,esp.cause some stoves were shipped with defective boards.Nice stoves though,would own one.
Thank you. We will try that and I will let the dealer know on Monday the items that we have done I’m sorry to sound stupid but what is WCI pressure
Water column pressure,just another way to say draft readings,you remember,using a gauge when installing the stove.
I do not believe the installer used a gauge when he installed the stove. He just turned it on had it fire up and then that was it and since it was fall and not cold we never had the stove running at all
The vacuum created by the combustion blower is an important part of proper burning,and part of your problems,cannot believe dealer did not check it.
Reactions: JRemington
Also,do not be shy about showing this forum to your installer,or the stove manufacturer.The manufacturers sometimes will follow these forums,for feedback.
I don’t believe he did As I asked him the last time if he could come up with a magnehelic gauge to check and he did not mention it.
I did check to see when it was made but the only sticker on the back says made in Canada
Thanks everyone you guys have been great. We will look to adjust the auger and the combustion tomorrow and go from there and yes I will be emailing our installer to let him know the items that we have discussed and ride. Frustrating after spending $700 for installation and 3500 for the stove
Page 36 in your manual is what it looks like,may be inside a stove cover,If does not have one,return stove.
Interesting. I am pretty sure he didn’t fill that out. The only thing I received from him filled out with the solid fuel heating questionnaire basically our WETT inspection
[emoji35] I am in the middle of a banking system conversion and I really don’t have time to deal with this this is why I hire professionals, sigh thanks again everyone we will continue on with the fight. Thank goodness it’s not actually cold yet
Yep got my manual in front of me see my installation datasheet completely empty
And,a sticker looking just like that is to be attached to your stove.Have the dealer remove the proper panel and show it to you,he will have to to get the serial number.
Thanks. We have looked at all of the panels, inside them that data sheet is nowhere. Something else I will be emailing the dealer about
I have tried to contact in Enviro directly but they don’t have any contact number unless you are a dealer on their website
I will start with my delivery again first then go from there
You can use"request a call" on their website,I understand why they use such a system.If that fails,call The Fireplace Center,in Kalispell,they have an excellent reputation,and will help,at least with getting you in touch.
Reactions: Powergirl
We have an M55cast burning in our showroom and get a 50 percent burn credit in February. At that time it's going home with me. It's my favorite of all our stoves. We recently sold a Max and that puts off a lot of heat. We only carry Enviro and Kozi.
Nice
They can't do anything more than we have. It's your Dealers responsibility to get this right. If he does what we suggested he will get to the bottom of this. This stove should never overflow the burnpot unless you don't dump the pot for a week. I've seen them keep burning with the pot full of ash. I have the auger cycles in my desk at work if he doesn't have them.
Reactions: Mt Bob
The newer Enviro stoves should have date of Man and serial number either under the hopper lid or on the back of the stove. I had one Distributor send us some with 2014 build dates. If this is the case with yours it may not have the updated control board and that may be the problem
Reactions: Mt Bob
We will take another look. We have not seen any sticker on the hopper door or on the back but the purchase invoice does show a serial number.
If you wouldn’t mind sending me the auger cycles that would be great. If you’re able to email them to me you could email them to lhaworth@integriscu.ca
I appreciate all the help you guys have given me. At least I have some stuff to talk with the dealer about. A little bit of information to help me when I’m chatting with him. Have a great night everyone
The board for that stove should have the number C-11652 on it. His other stoves other than the M55 will work as a test board. Before this is over you'll know more than they do.
