If your water heater is that old, I would replace it ASAP with a new one of same type. Who knows what kind of crud buildup is on the inside & on the elements, and it is on way borrowed time as far as suddenly springing a leak. At likely the very worst time.
You should be able to do that for less than $500 (without knowing your exact setup) and see immediate savings. I put ours up off the floor on a (very rugged) wooden stand, on a layer of 1" foam board. Wrapped a layer of 6" fiberglass around it (held in place with taped up foil bubble wrap - looks a little hokey but not all that bad). Added a heat trap at the outlet. It is very economical. Like I say, maybe $25/mo at similar all-in rates.
You should also be able to adapt a tank type heater to another heat source later if you want to, by T'ing off the bottom inlet or drain, and the relief valve fitting.
Yes, the water heater is changing soon, it's just hell trying to get someone to the house because of mud season. I think we've made up our minds to go with an LP on demand unit and a 40 gallon range boiler in the "attic" behind the bathroom above the utility room. The range boiler will be fed by the existing SWH and the wood cook stove going in this fall.
.(broken link removed to http://wikibon.org/blog/this-project-management-joke-is-often-reality/). That was an interesting project as the company that made the project knew how to make it in a factory but had never done a permanent installation. There was no NFPA classification on the fuel as it was so new so we didn't have a official code or standard to work from and had to make things up as we went along. We lucked out that despite it being a replacement for heating oil it doesn't meet the legal definition of oil so it cut out a lot of paperwork. I think Bates college in Lewiston Maine uses it also but it hasn't caught on with oil so cheap and no carbon tax. Neat stuff, smells like a barbeque restaurant when they unload it even with vapor collection and activated carbon filters. its made with the same process that they make liquid smoke type flavoring agents with.
