This may have been mentioned already, but can you crack open a basement window near the wood furnace? Maybe you need makeup air....?
I would say most certainly not!
They are using y'all for the R & D
Hope this video helps... At 1:12 mark in the video, see the large gap between the front of the stove and the air channel. Wonder if that gap should of been welded up? Also on the opposite side of where the air enters, there is a channel that doesn't have holes or seem to pull air from anywhere. Will have to talk to HY-C regarding this vertical channel (36 second marker shows the vertical tube).
I'm with you, if that's the case......that's nothing. For sure that will cause puffing issues.Does all primary and secondary air come through that little opening on the draft blower?
From my understanding.... yes.
Our furnace has a 3/4" hole when the primary is closed, and that's not enough (I keep it cracked open a little). We also have two 1.5" square holes for the secondary air and two 1/4" pilot holes. There's also 3 holes when the damper is open that are around 1" x 2" or so. That's for a firebox that is smaller than the firecheif, even with all that air, burns still lasting 8-12 hours. It doesn't seem hy-c thought out the design process. Like I've said before there's too much variable in the field.
Hey! Mr "stock" Kuuma...Sounds like another manufacturer I know...cough, cough, SBI....cough, cough Tundra.![]()
If that's the case then that's a terrible design! Primary and secondary air need to be from separate sources IMO. Otherwise whats to maintain the 75/25 (or whatever it is) split ratio once the T-stat is satisfied? As is, it can just go the path of least resistance...Pulls it through the draft blower. I'm thinking about adding another set of tubes to mine to add a way to naturally draft it.
@Mrpelletburner has been WAAAAAY more patient than I would be with a new unit if I was having extreme backfire issues like this!
Well, if not welded up, at least not gapping wide open like that.Wonder if that gap should of been welded up?
Hey! Mr "stock" Kuuma...![]()
I don't even own a string trimmer which is stock.
I bought mine 2-3 years old...and "pre-cracked", for cheap...it was to be more of an experiment/trial than anything else...so I knew what I was getting myself into...the original owner did not, although SBI did take good care of him...and because of that he bought a Max Caddy (and loves it)yeah, I agree, I think I would have told them to come pick their POS up long time ago myself. Although, I probably would have done the same thing with the Tundra after the first crack appeared or if I got one of the original "consumer beta test models" they used for "real world R&D" in which the ashpan setup potentially could have turned the owner's house into their very own personal CO bank.
They might not weld it solid for expansion/contraction reasons...ask SBI about that one! (I wonder how many Tundras they had to warranty before they figured it out?!)That whole run should be either a solid tube or welded IMO
This could be getting into design deficiency territory.
Think ima pass on this one...well, ya know, you may be able to buy a certain member's Fire Chief soon here for cheap to play around with. You'd also know what you'd be getting into.![]()
Think ima pass on this one...![]()
