sure looks like a bad gasket / seal to me. is the stove panel itself warped? I would be concerned about a hopper fire if it is leaking there.
does that burn pot look like yours in the hole pattern both on the main portion of the burn area and down by the beginning of the pot?
I think I got lost somewhere on the last post Smokey ...
What pot do you want me to verify ? The pot they removed ? the new pot that replaced it ? or the pot that I just gave a link to that stated it was for chain driven stove ?
with the old pot and the replacement pot I am still getting fire outside of pot on that shelf ...
the shelf area and the whole box around the burn pot was thoroughly cleaned of creosote build up before new pot was replaced ... that build up was from when the stove was throwing burning pellets out the back of the burn pot and that seems to have stopped with the new burn pot ( at least I do not see them falling on fire like I did before burn pot replacement ) but we are getting a fire outside the burn pot from somewhere ?
What gasket do you want me to look at of check ?
the tech had the stove hooked up to the draft reader machine 4 different times ...
all he says to me is everything seems to be operating like it should ( except we have a fire outside the burn pot) whatever the temp is set at it maintained it etc.
sorry for not understanding what you are asking
also I do not see or have never seen any smoke in the hopper ...
when I voiced my concern of fire Tech said it has no way of going into the hopper ...
which I do not totally believe because I have heard of hopper fires and would have to wonder how they got started ...
off topic question ?
why when I type my response do these emoticon come up when I hit post ... they are not there when I type my answer and they will not let me edit them to take them out...
Just wondering if they automatically pop up when you type a certain word ? lol !
I don't need you to check any particular gasket but where ever there is one you should check for warpage.
The exsistance of the holes at the begining of the burn pot your picture seems to show some while this http://pellethead.com/product/1-10-08736-burn-pot-weldment-accentra-advance-xxv-old-style/ doesn't.
Mine does the same thing. I just attribute it to creosote build up, which is what those pictures look like to me. Creosote fire just like in a chimney. If you do a search you might find creosote and Accentra go hand in hand. There were quite a few posts about problems with them years ago. It seems like once it starts you never get rid of it. I quit following the posts so I don't know if they ever found a solution. People were trying all kinds of modifications. I didn't. I just let it burn. It's contained to the firebox.
The more I think about it I recall there was a modification I believe some had success with. I don't recall all the details but they were drilling a hole and putting an air tube somewhere. Id try a search and maybe it will reveal itself. If you are feeling ambitious sometime you could give it a whirl. Im too lazy. Like I said I just let it burn.
I doubt there was anything wrong with your old pot. If you saved it take a straight edge anput it against the mounting surface. If there are no gaps then it is fine and you now have a spare.
Thanks for saving me some researching steps looking for that ;-)
So is that modification only IF I would get Smoke in the hopper at a future time
or should I look into it NOW because of the fire outside of the burn pot ?
Thank you Your assumption is correct I just looked it up with the name you suppliedI am assuming the clear tube you see is for the differential/vacuum switch. It goes from the hopper to the vacuum switch and senses stove vacuum/pressure..
I'm interested in what the tech turns up, as I have been burning mine with this issue for about 5 years. Its not my primary but it does see son duty during cold snaps.
