Harman PF100 6 blink from hell
The manual talks about draft control but damed if I can find anything about it but may be like
most harmans a flap on the air intake. It may be stuck open
Yes, I see they have a little draft control setting on the motherboard, but I have no idea how that works and what it uses to control the draft
So I have a Harman PF 100 furnace with a red probe and I have a 6 blink error code that I cannot seem to get fixed. I have recently replaced the motherboard and I have a 6 RPM auger motor on it. I have went through everything I can find on the forums and talking to a couple different companies. I do not appear to have any gaskets or seals leaking. I do not have a fresh air intake hooked up but The intake flapper is clearly operating. It seems to be feeding pellets perfectly fine. I’ve messed with the draft settings on the motherboard. I do not have a clog in anything that I can find. I’ve cleaned everything from the convection fan, the shaker chains, the burn pot, and the auger housing. I’m at a complete loss as to why it continues to blink. it usually flashes the error code and shuts down within 25 minutes to 2 hours, and it does not blow very warm air out the vents before shutting down. Any help or suggestions would be greatly appreciated!
[Hearth.com] Harman PF100 6 blink from hell
  • [Hearth.com] Harman PF100 6 blink from hell
I’m attaching some photos of my burn pot right after removal if I’m not mistaken the orange looking staining would be a potential air leak, correct?
.......and then???
