ya know incase the high limit switch fails. A baro damper is a mechanical device that can save your ass in a failure.I do have a baro damper installed but it only comes into play when temps outside get down in the teens, single digits or negative numbers. During negative temps if I did not have the baro damper in their the flu does over draft. Anything over -.09 or -.10 is over draft and best to keep draft around -.06 to -.08
The baro damper set properly will prevent over drafting and not block the flu like a manual damper.
