sloeffle
My Caddy has "wings" on the side. I can't remember if it has them in the back.The new Caddy I looked at on the showroom floor had a little "wing" under the center HE pipe, behind the firebox
I don't blame you. I got the Caddy because I always heard it was better to run the dog snot out of a smaller stove or furnace vs letting it idle. That is great until you have a cold snap and can't get any more snot out of the dog.Nope no tundra ll for me, this time it's go big or go home.![]()
.......Sunday should be the day I'm able to set it on top of the Tundra and connected to the duct work.
What are you currently heating with the caddy?I don't blame you. I got the Caddy because I always heard it was better to run the dog snot out of a smaller stove or furnace vs letting it idle. That is great until you have a cold snap and can't get any more snot out of the dog.![]()
Good idea! It is basically what they do with the Max Caddy, it is not a 'drive' or 'inverter' it is only switching wire...With all of the talk about blower speed controllers I figured it would be a good time to post this description of the one that I recently built for my Tundra using the factory motor and the high and low speed lead leads from the motor.
It would probably solve my frequent cycling problem...
We are currently heating a 2236 sq ft ranch in zone 6a / 5b.What are you currently heating with the caddy?
Right below the HEs, on the side of the air jacket, there are air deflectors (wings) to make the air go under and all around the HEs. The newer Caddys also have one in behind the firebox, under the center HE, to deflect the air forward instead of just shooting straight up, without much opportunity to pick up some heat along the way (if it just went straight up)Is that what you means by 'wings' ?
It is from a Max Caddy
View attachment 173162 View attachment 173163 View attachment 173167
That's awesome! I had an issue the first year on mine that caused the back to deteriorate. I believe it was from sitting in bad storage. Anyhow, SBI took care of me and sent a new firebox, along with firebrick, and other replacement parts. The furnace was branded a usstove, but since SBI built it, they took care of things. They even drove here from Canada to talk to me and take pics. I've never had an issue with their customer service. Can't wait to hear about the Max Caddy. Maybe someday I'll upgrade to something larger. Glad to hear they are taking care of things.Here is the latest on the warranty. I'll start by saying I am very pleased with the service I am getting from both SBI and L&M Fleet supply. First off SBI is taking the unit back. In turn I will receive a full refund. L&M called me last night to make sure everything was going to my satisfaction. I asked SBI if I could keep the unit to finish off the season seeing how I have a bit of money and time invested. They said no problem lets us know when you are ready in the spring. To me this is first class service and I could not ask for anything more. Hats off to L&M and SBI they are making things right by me. I highly recommend everyone to purchase from L&M if possible. Seeing how SBI is standing behind the tundra and providing great service I will be giving them more business by purchasing a Max Caddy. I also asked SBI for a replacement baffle that goes ontop of the secondary tubes
I think I cracked it by loading wood. I told them I would pay for it seeing how they are willing to take the unit back. They replied I'll send you one free of charge. I don't think they had to do that at all. So for now I'll keep burning the tundra and when the season is done she'll be heading north of the border.
You realize on a max caddy The speed of the blower can be adjusted . The factory setting I found to be just right . Far better than the tundra single speed which I also have owned. Of coarse each persons ducting and setup variesGood idea! It is basically what they do with the Max Caddy, it is not a 'drive' or 'inverter' it is only switching wire...
I hope SBI will add more 'control' over their speed controller... Max Caddy is locked at speed 2 until it reach 140F in the plenum, than it speed up to what I think is speed 4, than close the damper and speed up to 6 when it reach max temp (don't remember temp)... I rarely reach 140F with wood, not the way I run it... If it happen, speed 4 will cool the plenum pretty quickly... If I had more control over that controller, I would start it at speed 1, boost it at speed 2 when it get to 120F and back to speed 1 below 110F... It would probably solve my frequent cycling problem... So, for now I don't really enjoy that speed controller I probably paid lot for.. it is always at speed 2...
That's a good description of it, a tin can with a firebox sitting in the middle of it. The two side air deflectors are really the only thing in there to actively control air flow.tundras empty tin box design
Well, I dunno. When I went to research this subject at the local dealer a few weeks back, I was a little surprised to find that the Caddy is almost identical under the air jacket, except the Caddy has the reflective insulation like @lexybird mentioned his Max Caddy has. Oh, and the little deflector behind the firebox, under the center HE, Tundra just has a bracket there to support the HE, no "wing".I wonder if this is the reason SBI does not recommend removing the factory top and installing a plenum.
You mean your old one, or a new one?I'm following this closely at some point I may give the heatmax another shot
One question , in picture 2 what is that sq tube I see down in there I noticed that looking down into mine "without the top removed" couldn't figure out what that is for or does
Yeah, that is one of the two firebox support legsPS ..looking at it again maybe that's what makes contact with the floor ?
the old one , if heat production can be improved with a plenum and a few mods... and a little more work on the house maybe I could get it to do the job .... I like the new furnace there is more than enough hp to heat this place but with warm temps say in the 30's it will give more than we want.. Some days I let it go out...The other thing I worry about is my wife running it . She puts wood in but as far as adjustments to the draft and such, that going to take some time... The FChief will get hot fast and over fire is a concern...so I don't let her mess with the adjustments.....You mean your old one, or a new one?
I was telling my wife just the other day, the Tundra is the easiest wood burner to run that I have ever used, especially with the temp controller added onto it. Open door, rake coals forward, load wood, close door, set timer done. Only slightly more work building fire from cold stove...I was shooting for something that was easy for her to run when we got the heatmax the FC is old school and maybe a step back from wife friendly ..lol
There are no doubts there once you get the Heatmax fired up you can walk away....I took my wife down today and went over the air controls on the FC... I have a Dwyer manometer mounted to the side of the FC, showed her how that works...Next I'll walked her through a cold fire up and the needed adjustments and why and what for....I was telling my wife just the other day, the Tundra is the easiest wood burner to run that I have ever used, especially with the temp controller added onto it. Open door, rake coals forward, load wood, close door, set timer done. Only slightly more work building fire from cold stove...
And it really is a pretty clean burner...after installing the Tundra over at my sisters place I have not had to clean the chimney all winter so far (checked it once) When she was using the old Yukon Big Jack in its stock form the chimney needed cleaned once a month or so
