When the furnace is on "high fire" it could be too high, as @laynes69 explained so well, it dies off after the damper closes, and then you get condensation (and a mess) tooSorry I understood it as you have to much draft.![]()
Yup.I didnt know you could install them horizontally?
![[Hearth.com] Everything Drolet Tundra - Heatmax... [Hearth.com] Everything Drolet Tundra - Heatmax...](https://www.hearth.com/talk/data/attachments/172/172277-a991c4d8d36f36c52561009ef6f7a116.jpg?hash=NXPi6-3v7s)
Hi Craig.
They don't have the raw firepower of the old smoke dragons, it's more like slow n steady wins the race. How much house you heatin?
That is very likely an issue. That is almost 3 times the size flue that is called for. Once the intake damper closes and the firebox goes into "cruise" ( the hottest part of the burn) there is not enough heat being wasted up the chimney to keep draft going strong (-0.04" WC minimum) and that makes the fire die down. If you have a manometer it is easy to check this. If you don't have one, let me know, I can hook you up.
Gotta prevent backdraft. If nothing else, slide a piece of cardboard in next to the filter on the gas furnace (shut the power off) this will act as a poor mans backdraft damper temporarily.
You may not need one. A manometer would tell you for sure. You may be able to get by with a key damper (SBI says not to do this) but you would need a manometer to set and monitor setting the damper on each load.
You have plenty of room there for a baro by the way.
How's the wood you are burning.? These things like really dry wood, much more so than your old unit
$35 shipped. Brand new in the box Dwyer Mark II model 25...the same one most of us wood furnace guys usethe wood im burning is VERY dry red oak........how much for a manometor?
Yes and no. I'll shoot you a PM about it...does it come with everything to hook it up to the pipe?
You may not need baro cause you probably have low draft. Why are you not going strait into the supply? Also there is plenty of room to tie into the return plenum.What do you mean by going strait into the supply.....I need all the advice I can get.....after this winter I'm going to do everything in my power to get this thing running effeciently as possibleNo, and the numberses are backwards.You may not need baro cause you probably have low draft. Why are you not going strait into the supply? Also there is plenty of room to tie into the return plenum.
Also if you have no backdraft damper you are losing a lot of efficiency. From what I can see in your pictures you are blowing not only through the supply side but also back down through the A/C coil, gas furnace, and through the cold air returns. I would be looking to find a way to stop the back flow. Even if you were to build one in the rectangle main trunk before the 8" supply from the tundra. You are also going to have to line that chimney. I cannot believe there just isn't liquid pouring out of that clean out. Have you inspected the inside of your chimney yet?What do you mean by going strait into the supply.....I need all the advice I can get.....after this winter I'm going to do everything in my power to get this thing running effeciently as possible
Your tundra is located directly under your supply trunk. Your two supplies from the tundra should go straight up into the trunk of your gas furnace yet you came up with the 2-8" runs and elbowed over for some reason. Also install a damper in each of the two supplies from the tundra.What do you mean by going strait into the supply.....I need all the advice I can get.....after this winter I'm going to do everything in my power to get this thing running effeciently as possible
Looking at the picture of the "new" tundra III see my link from back on page 20 doesn't work anymore, and this Tundra II stuff is kinda hard to find on their site so I did a screen shot of a side x side comparison...this is about as much info as there is on their site right now.
How in the world will this help with cracking or over heating if you reduce the airflow to nearly half of what it was. Can't wait to see the results of that cluster ****.I bet that is the same plenum that is on the Heatpro, even if not, I just don't see them putting ducts on two corners only. I'm betting that there is a matching set of connections on the opposite sides, just like the HP...total of 10 possible connections.it's looks like 8- 5" supplies. I don't think they have any coming off the back but I could be wrong
Both are good. I have two flex liners, 1 two ply (don't buy this) with insulation wrap from chimney liner depot, and 1 "pre-insulated" liner from a company that sold out to someone else. I wouldn't get too hung up on all the different choices out there on liners. Just get a SS liner rated for wood use and roll with it. If your chimney runs through the house most of the way you can probably get away with non insulated. If it runs through un heated space for very far at all I'd insulated the liner if you have a large enough flue to fit it in. (and you should at 8x11)
Does the gas furnace vent to this same flue?
To be honest no for both questions. I looked around a ton for a website that had the info I was looking for and never found it. I ended up talking with a supply house I deal with who also deals with HVAC and he had the "slide scale" that gave me the info I needed. I also spoke with my HVAC sub about what I was doing and he provided me with info also. So in short when it comes to the HVAC I can't really help. What I can do is help with the duct design on a tundra seeing how I do have the duct numbers starting from 4" to 8" round. If you need those just let me know.@Builderml Can you explain duct pressures and what they mean for us non HVAC folks ? Or can you point me to a web site that has information about them.
Yes round flows better, most residential systems are designed at .1 static pressure.Did some Googling and found a pretty good article that talks about static pressure in your duct work. From what I read on this article and some others, you do not want more than .50 inches wc added together on your supply and plenum sides.
Also found a residental duct sizing guide. I do find it interesting that round ducts are able to push the same amount of air than a square or rectangular duct with more square inches.
Dunno about the rigid first hand, but I can tell you that the flex liners will expand and contract with temp changes and pop creosote off.I heard the ridgid ones have a smooth wall and get much less creosote build up....do you know if there is any truth behind this?
What I did was to have them crimp the bottom of the tee so I could put a leg on it down to the cleanout. I have a cap on the bottom that I pull for cleaning...I have a brick under the cap to hold it up onto the liner legalso based on my pictures if I install a liner and use the existing hole in my chimney to feed the T-connection through from the liner.......how do I access the cleanout in the bottom of the T?
After I finished I decided to pull the side air jacket panels off to look around again in preparation for designing a top to install a plenum on. So I'm lookin all around the HEs to figure out how the air flows through this thing and I notice something...a crack!
