bugman31964
After reading this thread it got me wondering if my summers heat version of this stove was performing at its best. So I had to do a cleaning today anyways and did a couple of things. First off I closed the feed restrictor plate down some. Then adjusted the hopper hatch so now it is very snug when the latches are closed. Seeing the post by HD41 sparked my interest and I fully examined the wear plate and burn pot. What I found was burrs from the manufacturing process. So I go out the files and stones and removed all of the burrs and a piece of welding slag. The plate sits very flat on the burn pot now. Lastly I checked the tightness of the burn pot bolts located below the door and found those to be somewhat loose. Not enough to allow the burn pot to move but probably loose enough to allow for air leakage. I will let you folks know if there is less ash build up tomorrow. My ash build up was not as excessive as the OP.
