I recognize that stove!Your loads should be N/S with the "tunnel of love" down the middle left open so the doghouse air can flow to the back.
Below are great examples of how I load mine up, although they are not my images. The below images should last way over 2 hours. When I pack mine like that I get about 4-5 hours of steady flames and and addition of 2-3 heat of at least 450 and up.
I would have to say and agree with here that your wood is not as dry as you think. Also, move your temperature gauge to the little 45 degree step up directly in the middle. Its proven to be the hottest spot.
View attachment 286987 View attachment 286988
Yea I saved it back when you were first running that. Notice your wavy air wash plate?
You and Dexter were the ones that convinced the 30NC were the way I wanted to go.
This is weird. My NC30 has a very responsive intake control. I can almost snuff any fire. When you move the intake control can you hear and feel the shudder sliding inside the stove? It's a flat plate that rides horizontally over a big hole to close off the air.Yes, I closed the intake shut before I touched the key damper. Again, intake doesn’t appear to do anything, open or closed makes no difference.
If the primary air is always closed it would definitely tend to want to reverse draft from cold. I know if I forget to open the primary air on my cook stove or Morso I have a hard time getting the fire going!This is weird. My NC30 has a very responsive intake control. I can almost snuff any fire. When you move the intake control can you hear and feel the shudder sliding inside the stove? It's a flat plate that rides horizontally over a big hole to close off the air.
If you can get down there behind the stove you are able to look into that 3" round outdoor air connection in the back and actually can see the inlet hole being closed as you push in the air control. You can see it to verify that this plate is installed correctly though I don't know what to do if it is not correctly installed. Look in and up with a flashlight. The hole in there being covered by the movable plate is kind of triangle shaped.
Most people that say that don't know how to run them and don't understand secondary combustion. That's understandable if they got the 30-NC as a smoke dragon replacement.Most customers I Know with them say the air control doesn't do allot.
TrueMost people that say that don't know how to run them and don't understand secondary combustion. That's understandable if they got the 30-NC as a smoke dragon replacement.
Can we assume that nothing else in the house was happening that might affect draft. No big exhaust fan turned on? If not, it sounds like the chimney would benefit by putting in an insulated 6" stainless liner.As a reminder, I have a large masonry exterior chimney,.
That said, let me run this scenario by you. I just started my fire this morning. Stove was still luke warm with coals from last night, thermometer read 150. I loaded it up like the picture earlier in the post and started it. The draft was absolutely amazing. I could see the smoke being sucked up through the top front section with the door wide open. I have never seen this before. As soon as it started to heat up smoke billowed out, like I lost the draft as it got hotter. Last night, at 650 degrees, smoke piled out once the flames went out on my last load. I had to open the windows upstairs to air the house out it was so bad, and the door was only open for less than 5 seconds. It was my fault for letting the flames go out, but it was still reading 650...
My question is, shouldn't this be the reverse? Shouldn't the draft be amazing once it gets hot, not when its cool/cold? Not sure if it matters, but outside temp is 30. I wasn't sure if this info would help diagnose my issue.
No, the tubes should be straight. I would try taking it out and straightening (gently) by hand before replacing it. My original boards also bowed front to back. It ran better when I flipped them over so they were touching front and back and off the middle tubes. Note that the tubes are each slightly different by the angle of the holes.
This installer sounds like a decent person, one of the reasons why you may or may not be noticing the air control working is because its not a lightning quick operation, especially when the fire is in the incipient stage of growth or full growth and the firebox is over 1100 deg f, thats when secondary combustion takes over and there's no controlling that air take.Just had my fireplace inspected and cleaned yesterday. They said the chimney is in good condition, with proper clearances from the roofline. They said I was sold double wall pipe by last years inspector (who I didn't trust and almost had to call the police on as the two workers were fighting with each other) and didn't need it. I have a 7 inch clay liner that is in good shape, but he believes it is the main cause of my problems. He is quoting me a 25' insulated steel liner (still waiting on that). He also said the thimble is loose and may be letting air in. He checked my wood and said he didn't think that was the main cause because only a few pieces were too wet.
