NE WOOD BURNER
- Dec 30, 2012
- 754
(broken link removed to http://www.woodstove.com/pages/guidepdfs/Good_Chimney.pdf)
Here is a good read from Woodstock
I was thinking after my last post that perhaps a diet change may solve the problem. I may be all wet but what I believe is happening is that at full burn, the oxygen is used up in the primary combustion and there is not enough left to completely combust (if that's a word) the gasses in the secondary since there is no means of supplying secondary air in Mike's boiler. Perhaps (dare I say it) adding wood with a little higher moisture content would make for a smaller fire which would then use less combustion air in primary and allow more to flow to the secondary tube allowing all the gasses to ignite. There may be other odors that are emitted but the most offensive one to me was when my Wood Gun was fireing full bore. Other problems will arise with this "fix" but it sure beats abandoning the wood boiler in favor of oil.Good point, Fred. Honestly this odor issue puzzles me as it is not something I have experienced. Like I said earlier, the only smell I get at full burn is a faint toasted wood smell. No sulfur/acrid smell ever.
All this points right back to incomplete combustion and storage is not going to solve things if that is the case. Tough situation until this aspect is solved, IMO.
Noah
I think the "other boilers" they're referring to don't include other gassers."During the off cycle, wood gas inside the firebox condenses on the inner walls forming a solid that will eventually fall off. This combines with the remaining fuel thus adding energy that in many other boilers goes up the chimney." quote from wood gun web site
This "SOLID" I would think is creosote.
"During the off cycle, wood gas inside the firebox condenses on the inner walls forming a solid that will eventually fall off. This combines with the remaining fuel thus adding energy that in many other boilers goes up the chimney." quote from wood gun web site This "SOLID" I would think is creosote.
My Eko burns the creosote on the walls of the upper chamber. I know it is burning because any deposit with any amount of thickness is crumbly. I burn to storage and burn very hot but I have never gotten that odor from it. I do agree, however that storage is worth a try since it has so many other merits it would.'t be a waste of money.Creosote burns with a unique smell and it burns hot. with a short stack on the chimney any applaince will have incomplete combustion. the distance to the diagonal nieghbor maybe less than the 100-150(300-450') yards as stated. but the stack hieght is lower than the residence not served by the appliance.
That looks like it would focus it directly at his house.![]()
Does anybody really believe that burning at nite will change things?
I think this neighbor got a bee in his bonnet over this boiler and no matter what he's going to find a way to complain.
Is chimney length really that big a factor though in getting enough air for proper burn in the burn chamber with a unit with such a forceful forced draft as the Gun? You can do a short horizontal pipe out of a Garn & I've never read about these kinds of issues with those.
It has a large centrifugal fan within the unit that draws combustion air through the firebox and through the tubes snd sends it out thru the cyclone. You were so "matter of fact" about your fixes I would have thought you would know how the unit is designed. If you do find a schematic of the design you will probably not be so sure your changes will work and that flue temperature at different points will have little effect on the operation. I can tell you are very knowledgeable on most systems but the Wood Gun is a totally different beast.The Garn was not designed to idle.
This boiler would be simliar if the fire where to burn out as is being suggested by adding storage.
I can not find on the wood gun site, but it appears the fan is pulling air through the firebox? Is there a draft inducing fan on the exhaust?
Most 'nuisance' burning ordinances are written to limit the amount of 'visible smoke' or 'excessive smoke' or if they want to get really technical they limit the 'opacity level' of the smoke for x number of minutes. So burning to storage, which means very little smoke, should satisfy the local ordinances. It's doubtful that there are any laws regarding the smell of a wood burning appliance on the books. And if there aren't any all Mike has to do is comply with the rules regarding smoke output. His neighbor would be able to complain all he wants and nothing would happen.
I think the one thing that has slipped from the minds of all the helpful people is that the Wood Gun puts out this odor at full burn.
The pool is on my property and the fence is just around the pool.Is the pool in the picture yours or the nieghbor's?
Is the fence line the boundary of your property?
