Deets
I’ve got an endless supply of wood. 13 acres of woods here, and good friends with about 4 different tree company’s that love to dump wood.
I will suggest at least 6 cords of season wood ready for a gasser and 12 cords if you go with a MP.I’ve got an endless supply of wood. 13 acres of woods here, and good friends with about 4 different tree company’s that love to dump wood.
No gasser is rated for anything outside of wood. I know someone that burned coal in a E series and had to replace all the refractory and warped all the steel. Burn chamber temps were double a wood fire.I also work at a coke and stone foundry from time to time. I brought a bucket of coke home and threw in the burner. Must not have been running hard enough to make use of it though.
maybe in a gasser?
I guess I’ll leave that be then.No gasser is rated for anything outside of wood. I know someone that burned coal in a E series and had to replace all the refractory and warped all the steel. Burn chamber temps were double a wood fire.
bottom line is you will need to be three years ahead on wood to have properly seasoned wood every year. No matter what anyone tells you the hardwoods will not season in one or two summers.
Of course, but it had huge checks and cracks in a month, usually it takes several months.Fir and spruce softwoods can dry much faster than most of the dense hardwoods.
I would agree, and how well the wind and sun can get to your wood stack. I've seen wood get to 15-20% in one summer, this year it isn't happening for me tho, it's super wet this year.Weather definitely plays a big role
Does anyone have a Crown Royal dealer info you could share?So, does the heat master G7000 or the Crown Royal 7400e have an O2 sensor? Or are we talking different stoves all together?
Not that Crown Royal, but I do agree with ya!! LolUmm Crown Royal...
my favorite rye
I know this is an old post but I too am now looking between the 7200E and 7300E, have 2400sf and was quoted 11-12k for 7200E and 15-16k for the 7300E! Did you get the 7200E and do you like it? Money is tight and need to know if it will cover my needs. BTW, I’m really well insulated but we keep the house at 75° when home, 68° when sleeping!I am heating 2300sq ft. The home is insulated fairly well, but nothing crazy. Winter temps average 20*F, with the max low of around -10* F. I plan on heating domestic hot water. Was doing some research, and was looking between the 7200e and 7300e, not sure which.
